Steering intermediate shaft
Posted: Thu Oct 04, 2012 2:15 pm
by Paul Roberts
Hi have a fair amount of play in the steering of the Silver Sprint. Looks as if the splines on the intermediate steering shaft have worn and possibly the flexible coupling the shaft goes into. Ideally I would like to replace with Triumph parts (new old stock) rather than reproduction. Any names to get in touch with?
Paul Roberts
Perth, Western Australia
Re: Steering intermediate shaft
Posted: Thu Oct 04, 2012 7:59 pm
by 80Sprint
As this is posted in the Motorsport section why not go aftermarket or is it the wrong section. A solid mount would be better but not sure you want to go that route.
Posted: Fri Oct 05, 2012 7:17 am
by baz
Hi Paul,
On my Dolly's I have always replaced the "flexible"uni joint with a "solid" type uni joint. i believe a shotened down one from a 2500 isteering column is used. I can try to get a pic of mine over the weekend but I am sure Dave would know about this mod.
Baz
Yes ............
Posted: Fri Oct 05, 2012 9:45 am
by sprint95m
It is possible to use a T2000 manual steering upper UJ in place of the Dolomite lower joint.
It is also possible to recondition a Dolomite lower joint using Superflex bushes.
Upper Dolomite intermediate shafts should be replaced with new.
Posted: Tue Oct 09, 2012 2:37 pm
by Paul Roberts
Thanks for this. Yes, would very much like to replace with new - problem is finding the new part. Canley Classics can't help and Quiller can only do S/hand. Any other suggestions?
Thanks Paul
Posted: Tue Oct 09, 2012 4:40 pm
by minidave
Hi i got my solid type from winns Dave.
