Page 1 of 3
Dolomite Sprint Motorsport blocks
Posted: Thu Oct 04, 2012 2:22 pm
by Dolly racer 33
Hi guys, I am looking for some Dolomite Sprint Motorsport cylinder blocks. Probably easier to find hens teeth I know.
These blocks have much thicker main bearing webs & were used from 1977 onwards in the race Dolomites & in the F3 Unipart cars. I have one currently in a race car which allows much more power at higher revs, The one currently running regularly uses over 9,000 rev/min. If I cannot find any I am considrering having some made, dependant upon cost. any interested parties can contact me.
Ken.
Re: Dolomite Sprint Motorsport blocks
Posted: Thu Oct 04, 2012 3:27 pm
by Dolly-Nut
I see you're called Ken, I don't know your surname but I know of a Ken Osbourne who has at least 1. If this is not you I can get you in touch with him... :?
Alternatively to having some made I think you have the choice of either boring an 1850 block or possibly a Saab 99 1700 engine. These apparently have more meat left on them. There will be more knowledgeable people on here that may know more...
Posted: Thu Oct 04, 2012 3:31 pm
by Dolly-Nut
Posted: Thu Oct 04, 2012 4:05 pm
by soe8m
Hey, i know that guy.
Posted: Thu Oct 04, 2012 4:43 pm
by 2drToledo
It might be worth trying to contact Terry Van Der Zee in Dorset: Bere Regis way, I think. The last I heard he had quite few special components of this nature. Googling might be the easiest way.
What are you building now Ken?!
Posted: Thu Oct 04, 2012 5:13 pm
by Dolly racer 33
I have read the Saab thread. We have to use original Sprint blocks. Standard useable blocks are in very short supply, I know Terry van der see & Ken Osbourne but doubt very much they would have any motorsport blocks . In the 25 years I have been running sprints I have only ever found 1.
If you want to achieve serious power without the possibility of cracking blocks above 7,500 rev/min the only option is new Motorsport blocks. Subject to cost I am considering having some done but it really does depend on cost. Obviously the more I can sell, the cheaper they will be.
I am currently involved in building or preparing 6 race sprints, if I can make them more reliable and produce more power then I must look to this route.
The Sprint I am running with the Motorsport block produces over 200 bhp @ 8,000 rev/min compared to 195 @ 7,300 rev/min from my standard block. I have not measured the power at 9,000 rev/min as I have not been brave enough.
Ken Clarke
Posted: Thu Oct 04, 2012 5:24 pm
by xvivalve
Ken,
I have a prospective new Client who owns a precision casting foundry (iron and aluminium). Want me to have a word in due course? Subject to cost, I could be interested...
Alun
Posted: Thu Oct 04, 2012 9:10 pm
by Dolly racer 33
Alun,
thanks, I will bare that in mind. I think the most expensive part will be the pattern making.
Ken.
Posted: Thu Oct 04, 2012 10:40 pm
by Dolly-Nut
I will cross my fingers and check all my blocks just in case... :D
Ken assured me that he had one in one of his cars.
Is it not possible to strengthen a standard block enough? Or is that ruled out from regulations?
This sort of thing interests me.
Posted: Thu Oct 04, 2012 10:43 pm
by soe8m
Dolly-Nut wrote:I will cross my fingers and check all my blocks just in case... :D
Bracing it but than the Dutch way. New machined bearingcaps that slot into the brace. No movement at all. Not like the alu ones with long studs and a lot of nuts and washers.
Posted: Thu Oct 04, 2012 11:33 pm
by Dolly racer 33
You can never brace it enough. The main cap studs have holes at the top of the thread on the standard block & the websaround the main bearins are only about 3/8 or 10mm thick. on the motorsport block they are over 1" or 25mm thick with the possibility of making them 4 bolt mains. You could never make the standard block this strong.
I have used a13mm plate with long studs in the bottom of the block, I was the first to do this but still after regular 8,000 rev/min plus useage the blocks crack & it is a lot of work to recreate a 'race spec' block.
Ken.
Posted: Thu Oct 04, 2012 11:41 pm
by xvivalve
Undoubtedly, the pattern(s) would be by far the expensive bit. I wonder if any originals survive; stranger things have happened. Any idea of who the original casting firms were?
Posted: Sun Oct 28, 2012 3:35 pm
by Hobo
Have we got any idea of the number of people who would be interested?
Posted: Sun Oct 28, 2012 7:55 pm
by Dolly racer 33
About 6 interested parties at present& that includes me & 3 of my customers so at present not viable> I will not spend £20,000+ to sell less than 10. I need 15 to 20 orders before I would contemplate starting the job.
Posted: Sun Oct 28, 2012 8:09 pm
by lazeruspete
I may be interested depending on price.....!
