Did these rails recently as you all know.
Had 2 minor issues;
1, Tube was set at the wrong angle (top was back about 15 or 20 degrees too far). Fixed by whacking forward with a big hammer (v. easy).
2, Rail seemed too short for floor pan. When tube was inserted (at correct angle) the back of the rail would not clear the rear of the floorpan. Fixed by tacking and whacking to suit (less easy but not hard). Could have cut a small piece out of the rail but it wasn't necessary.
Did lots of 'up and down' with a bare subframe to make sure all lined up.
All in all, you need two people to do the job properly. It takes time but it's worth double checking everything so the subframe doesn't put unnecessary strain on the rubber bushes when you bolt it up permanently.
Overall verdict?? Allow a days work for two people to do it if it's their first time
Also wait for a still day as the MIG don't weld too well in the wind
