weak battery
cleverusername
weak battery
#1 Post by cleverusername »
I am problems with an engine on a 1500HL, basically if you rev it and then let it idle, the engine struggles, then gets back up to idling speed. I can get the same effect by turning on the headlights. The battery is very weak and I can only turn the engine over with the help of another battery which came off an XUD engine.
Would a weak battery cause these symtoms? Can I try connecting the other battery to the engine? It is from an 1.9td XUD diesel, and is a bigger battery than the little Dolly one. Would it damage the Dollys electrical system?
Tims Triumph
Re: weak battery
#2 Post by Tims Triumph »
Is this when Cold or Warm?
What's the normal Idle speed?
I wouldn't imagine it would be anything to do with the battery as that's not "powering" the engine in any way.
Most likely you'r idle speed is either a little to low if this happens when warm.
If this happens when cold, then perhaps it just needs a bit more choke.
cleverusername
Re: weak battery
#3 Post by cleverusername »
Tims Triumph wrote:Is this when Cold or Warm?
It is happening when it is warm, tried mucking around with engine timing and carbs. Think we have cracked it and next time same issue. Very frustrating.
Oli_88
Re: weak battery
#4 Post by Oli_88 »
Your battery either needs a proper charge, or replacing. Check the voltage with a multimeter. Also, check the voltage while running to make sure the alternator is doing its job, should show 13.5 with the engine at idle iirc.
Engine struggling when extra load is applied to the alternator would suggest it's goosed, or you have an incorrect fuel mixture.
Hit it.
cleverusername
Re: weak battery
#5 Post by cleverusername »
Oli_88 wrote:Your battery either needs a proper charge, or replacing. Check the voltage with a multimeter. Also, check the voltage while running to make sure the alternator is doing its job, should show 13.5 with the engine at idle iirc.
My guess is fuel mixture, the volt meter gives a reading of 13 volts or there abouts. I have taken the battery out and put it on a battery charger. Last time I did this I used a low charge setting, bit afraid of destroying the tiny Dolomite battery. This time I am going to give it the full beans and see what happens.
Dolly-Nut
Re: weak battery
#6 Post by Dolly-Nut »
As stated it will probably either be a too low idle (should be 700~ min when warm) or a lean mix. Check your plugs for colour.
Re: weak battery
#7 Post by Jon Tilson »
This isnt really a restoration project thread, more general dolly.
Sure it will get moved in due course....
I'm happy to look at this for you if you are anywhere near west london.
Sounds like a discharged battery. How or why needs a bit more diagnosis....
cleverusername
Re: weak battery
#8 Post by cleverusername »
Jon Tilson wrote:This isnt really a restoration project thread, more general dolly.
Thanks, turns out it wasn't the battery. Got it going, then found fuel on top of the float chamber nearest the grill. Engine off quickly, didn't want a fire. The float chamber is loose, and we need to take off to get a better look. More than likely ruining the mixture. Oh well, at least it didn't catch fire.
Re: weak battery
#9 Post by Jon Tilson »
Lots of threads on this.
and this article....
https://www.dollywiki.co.uk/wiki/SU_Carburetor_Tuning
cleverusername
Re: weak battery
#10 Post by cleverusername »
Jon Tilson wrote:Lots of threads on this.
Thanks I am going to need all that. Hope that will fix it, well that and replacing the middle section of the exhaust that has a hole in it.
