Weber manifold threads
Posted: Wed May 15, 2013 7:39 am
by wiggybum
Having aquired a secondhand weber manifold for the Sprint, I now need to work out what size threads are used for the studs,thermostat housing, water pipe & temp sender.
Anyone got an idea?
Re: Weber manifold threads
Posted: Wed May 15, 2013 8:17 am
by Dolly-Nut
Studs: M8 (13mm Nut).
Thermo housing is usually bolts but 5/16 UNC.
Temp Sender: 5/8 UNF? - Water pipe the same?
