Oh no, not FRENCH!!!!
Posted: Sat Jun 15, 2013 10:02 pm
Tilly the red Daf went to a new home on Wednesday, and has been replaced (as a straight swap) by George.
He's not a Daf, he's not aircooled, and hes got this strange thing called a "clutch" (as I forgot heading in to the first services on the way to Devon. He gently reminded me with a kangaroo impression :-[ )
But he's big enough to carry clock & watch stuff, he's reasonably economic despite his missing (for now) 5th gear, and he's actually a rather pleasant place to be stuck for hours getting through roadworks followed by several accidents on the M5 from Bristol northwards!
He's also F%£#ch
Still, despite being by far the newest car I've had for several years, he doesn't quite look like "just-another-modern" (although probably did in his day!):
I'm afraid the rather fetching greyhound stickers will be coming off because he'll be getting Anglesey Watches and Clocks markings in their place.
There are a few snags to deal with which, on a daf, would be an hours work or so but access on George is, frankly, abysmal, so they'll probably take a lot longer!
Speedo cable is disconnected behind the dash. It appears to be an engine-out job to reconnect it but I'm sure there's a way!
Tachometer doesn't work. Most likely to be the TDC sensor mounted about half-way down the back of the engine. That's going to mean turbo intercooler out as a bare minimum for access, and probably battery + battery shelf.
Driver's window is currently held up by a block of wood. That one's quite straightforward, just need to order a regulator of EBay and fit - what could possibly go wrong?
There's a mystery leak creating a puddle under one half of the back seat. Isn't there always?
The headlining material isn't exactly secure, although the gentle wave effect in your rear view mirror is quite soothing as it ripples in the breeze ;D
There's an untraced water leak (used about a litre in 300 miles) which is likely again to be down the back of the engine. This car needs a removeable bulkhead! However, he has a "coolant low" light that comes on well before there's any overheating risk (as well as a temp gauge AND an "overheat" light - Daf take note!!!) , so that one's not as much of a problem as it might be!
5th gear is currently for coasting downhill only - as soon as you come off the over-run he pops out into neutral. But he came with a spare box, and 5th gear can be changed with the whole thing still in the car by removing an end cover. Nice
Need to get him a towbar cos he'll probably be rather good at that!
Jobs that have already been done are:
Injector pump boost compensator pipe is now reconnected - boy does he go better with that!
Glow plug light on dash now works (swapped the bulb with the airbag warning one because he also has an airbag light on the bag itself and MOT only needs one)
One of the remote keys now works reliably without having to crush the button into dust with your fingernail. Just need to do Sian's now.
So, I still get to play mechanics, while Boris is relieved of the heavy lifting he's been doing for the past 10 months or so - all good in Anglesey
He's also F%£#ch
