Misting up.
Misting up.
#1 Post by MIG Wielder »
Do you have a good solution to the problem of safety goggles misting up when using them with a face mask while using the angle grinder ? None of the standard de-misting fluids seem very good; the goggles are vented underneath supposedly to get airflow through, but again it doesn't seem to work very well.
Thanks very much,
Re: Misting up.
#2 Post by soe8m »
Relax and don't sweat.
Tony Burd
Re: Misting up.
#3 Post by Tony Burd »
Use a fan to blow air across your face, but make sure it is not blowing the grinding material in your direction.
Not tried this myself, although sometimes when I am using my angle grinder if the breeze from the grinders motor cooling fan happens to be blowing towards me the goggles stay clear
SprintMWU773V
TDC Staffs Area Organiser
Re: Misting up.
#4 Post by SprintMWU773V »
If you hold your breath then you won't steam up nearly as much!
Or try some safety glasses which tend to have more ventilation. I have some good wraparound type ones which are actually higher rated than my goggle mask and don't mist up.
Re: Misting up.
#5 Post by soe8m »
TrustNo1
Re: Misting up.
#6 Post by TrustNo1 »
Strange you should ask this as today with my new mask i was using earlier I have the glasses misting up so much they were wet inside and was going to post the same question.
Re: Misting up.
#7 Post by MIG Wielder »
..... I've just acquired one of these. Its a " Forestry helmet " with a clear visor and ear defenders for less than £30. And it works really well. I'm impressed. It is quite heavy on the head though.
This sort of thing.
Draper 69933 Safety Helmet
dave comer
Re: Misting up.
#8 Post by dave comer »
Might be worth going to army surplus for some "anti-dim". Used to prevent lenses misting up when using a respirator. Seem to recall it was very effective, not that we wore respirators much in the Navy.
Edin Dundee
Re: Misting up.
#9 Post by Edin Dundee »
I used to use this, worked OK:
http://www.ebay.co.uk/itm/like/18098439 ... 108&ff19=0
This gets good reviews, never used it myself:
http://www.amazon.com/Clarity-Defog-Ant ... roduct_top
AlanH
Re: Misting up.
#10 Post by AlanH »
Make sure that your mask fits snugly and use a bit of masking tape to tape it to your nose This will stop your breath getting in to your goggles.
Works for me.
