1500 FWD Solid clutch Pedal
Posted: Wed Jun 13, 2007 4:45 pm
by Paul1500
After Fitting a new clutch and a new slave cylinder and master cylinder seals to my 1500 FWD and after bleeding the system the clutch pedal is solid and won't budge even with the release fork removed, Any Ideas what could be the problem ?
Maybe I need a new master cylinder?
Paul
Posted: Wed Jun 13, 2007 5:00 pm
by 1300dolly
jammed slave cylinder or or has been bleed incorrectly. try rebleedin with the slave out of the bracket and a clamp holding the piston in.
Posted: Wed Jun 13, 2007 5:21 pm
by Paul1500
After bleeding the system the clutch pedal worked for a while then went solid
Posted: Wed Jun 13, 2007 8:39 pm
by xvivalve
How long? A few pumps? maybe you put a seal in the wrong way round...
Posted: Wed Jun 13, 2007 11:03 pm
by Paul1500
A few around 15 ish, I have n't touched the seals in the slave cylinder as it's new and someone I know changed the the main seal and the outer boot on the master cylinder.
New Parts fitted so far:
Clutch cover
Clutch plate
Input shaft
Slave cylinder
New seals master cylinder
pipe from master to slave
AND STILL IT DOES N'T WORK
:cry:
One more question, in the Haynes manual it shows a pipe that the input shaft slides in to between the gearbox and the clutch cover this is missing from my car how important is it ? and can they be bought ?
Posted: Wed Jun 13, 2007 11:07 pm
by mbellinger
I believe that you should have the "pipe", and Mick Dolphin should be able to supply you with one.
Did you use the special grease on the input shaft? If not you need to. It can be bought from Steve Waldenberg - details via Dolly Mixture under FWD Register spares.
Posted: Wed Jun 13, 2007 11:43 pm
by 1300dolly
Did you use the special grease on the input shaft? If not you need to. It can be bought from Steve Waldenberg - details via Dolly Mixture under FWD Register spares.[/quote]
but not in the last two issues of DM.
Posted: Thu Jun 14, 2007 8:10 pm
by Paul1500
mbellinger wrote:I believe that you should have the "pipe", and Mick Dolphin should be able to supply you with one.
Thanks he does and I've ordered one for only £6 inc P&P
Once again Thanks
Paul
