Valve clearances for TT10106
Lee Flintoft
#1 Post by Lee Flintoft »
TT10106, can anyone tell me what the valve clearances should be, is it 10-11 thou inlet, 12-13 thou outlet?
#2 Post by xvivalve »
Spot on...and needs to be timed in at 106 degrees to be 'spot on'!
Dollyboy
#3 Post by Dollyboy »
spot on
:lol:
Lee Flintoft
#4 Post by Lee Flintoft »
What about 16VT14, I believe this is a Kent Cam, whereas TT10106 is Triumph Tune. Am i confusing myself here?
The Cam (and I never doubted you Dave) is 408 thou which according to the list I have is same as SPRINT cam, which would need the valve clearances mentioned above, but speaking to Kent Cams direct, they have advised 9-10 thou inlet, 11-12 thou outlet? :bash:
Any cam specialists out there who can help?
#5 Post by Mad Mart »
Sfunny, I've got a new TT10106 equivelent from Jigsaw (Newman cams) & the installation figure I've been given is 110 deg. ATDC? :?
dailysprinter
#6 Post by dailysprinter »
Personally I go 7thou inlet and 8 exhaust as in the leyland ST manual. I find they rattle like hell below that.
1979 Triumph Dolomite Sprint Highly Modified
2006 Triumph Sprint St 1050
2012 BMW 318d Touring
TONYSPRINTER
#7 Post by TONYSPRINTER »
i have a kent cam KCL14 with 0.424 lift what should my clearances be ?
any help thanks :lol:
#8 Post by Mad Mart »
read my reply in your thread. :wink:
#9 Post by Mad Mart »
Here's my new one. :D
#10 Post by xvivalve »
The Triumphtune cams were ground by Kent.
The figures I quoted were given me by Pete Cox of Cox & Buckles, (now Moss). He is a bit of a cam and gearbox guru...
Lee Flintoft
#11 Post by Lee Flintoft »
Hence my confusion Alun! but any advice gladly appreciated to digest and ponder.
