Steering advice
Posted: Wed May 07, 2014 2:06 pm
by Paul Roberts
Hi everyone
One of the things that continues to be a problem with my car is play in the steering. I have replaced the lower steering knuckle joint in the past 12 months, but once again it is knackered. I am a little worried the car won't pass scrutineering for the Albany race meeting as is so I do have to do something about this quickly. The car is only used for competition, so I am hoping there is a better solution than cheap reproduction parts from Rimmers and the like. Any help gratefully received.
Paul Roberts
Perth, Western Australia
Paul..
Posted: Wed May 07, 2014 2:14 pm
by sprint95m
Two options...
1. Rebuild an original (not reproduction) coupling using Superflex bushes.
2. Use a forged (not pressed) UJ instead (from a T2000 manual steering). The intermediate shaft may need shortening.
Re: Steering advice
Posted: Thu May 08, 2014 7:23 pm
by Dolly-Nut
Be sure to check it hasn't come loose, they're good at this. Loctite is recommended.
Re: Steering advice
Posted: Fri May 09, 2014 10:34 am
by cliftyhanger
Escort gp4 steering joint is basically the same thing. I needed to reduce the shaft length a bit and it was then a tight squeeze.
Re: Steering advice
Posted: Sat May 10, 2014 5:44 pm
by trackerjack
I used a lower joint from an Allegro as it is virtually identical to the Escort item.
I also have a good as new fast rack for a Sprint here in my garage 2.6 turns lock to lock.
For the correct amount of beer vouchers it can be yours.
Re: Steering advice
Posted: Sat May 10, 2014 7:02 pm
by Dolly-Nut
trackerjack wrote:I used a lower joint from an Allegro as it is virtually identical to the Escort item.
How many beer tokens exactly?
Re: Steering advice
Posted: Mon May 12, 2014 12:12 pm
by Paul Roberts
Trackerjack, your offer is very tempting. There are many excellent craft beers here that I can recommend following many hours of extensive research!! My problem, of course, may be getting said craft beer to you in one piece!! Still, I am wondering how difficult it would be to get a steering rack shipped? Food for thought ...
Allegros were never sold here in Australia, but Escorts are obviously a ubiquitous model so that does give me a potential alternative.
Once again, thanks to everyone who replied. It is very much appreciated. This forum is sometimes a bit of a lifeline. I have a great group of Triumph "aholic" friends with Heralds, Mk 1 PI race cars, Spitfires, Stags, TRs from 2 to 8, but I am the only one in the club who competes in a Sprint. All of the feedback received when I do post on the forum is always greatly received.
Paul Roberts
Re: Steering advice
Posted: Tue May 13, 2014 3:22 pm
by Paul Roberts
Can you tell me whether it is Mk 1 or Mk2 Escort for the steering knuckle as there seems to be a difference. If someone can let me know ASAP, I can probably get this ordered and on the car before scrutineering in a week and half time. I am assuming this is what I need.http://smckaperformance.com.au/shop/ste ... ng-long-2/
Thanks again
Paul Roberts
Paul...
Posted: Wed May 14, 2014 9:40 am
by sprint95m
The Escort mark one group four cars use a T2000 manual steering upper UJ.
That is the one you want.
In the UK proper forged original equipment UJs are much cheaper from Triumph suppliers such as Chris Witor
than they are from the Escort specialists.
Apparently they offer pressed joints on Escorts because of clearance issues (?) but there is plenty of room for the
superior forged type on your Dolomite :) .
PS from the T2000 register register it seems there are a few saloons racing in Western Australia, a possible source of parts?
Thompson is the surname of one such person...
Re: Steering advice
Posted: Fri May 16, 2014 6:29 am
by 80Sprint
Not in my experience Ian. I fitted the forged type from one of the rally suppliers recommended on here and had to shave a bit off the inner wing seam to get enough clearance. It was easy enough to do however and still worked.
Re: Steering advice
Posted: Sat May 17, 2014 8:53 pm
by Edin Dundee
80Sprint wrote:Not in my experience Ian. I fitted the forged type from one of the rally suppliers recommended on here and had to shave a bit off the inner wing seam to get enough clearance. It was easy enough to do however and still worked.
I thought I was the only one who had to do this!
Re: Steering advice
Posted: Tue May 27, 2014 12:52 pm
by Toledo Man
Ian, Andy Thompson is the man to whom you refer. He also posts on the Club Triumph forum and his Blog is featured on their website.
Paul, if it is just the rubber that's perished then the Super Flex bush option is the one to go for. The same hardness as rubber with the durability and longevity of poly. Super Flex should be easily available in your corner of the universe.
