Note the pin hole for oil supply
Secondly a Jaguar OE part I have sourced:
A much larger hole in the side of the casting for oil supply, and also through the rubber pad for chain lubrication
The Jag part is more expensive, of the order of low twenties through my supplier compared to the Rolon brand which is about a tenner less, but I'll not be using Rolon ever again.
Strangely, unless I'm not recalling the assembly correctly, the shaped spacer which sits between the main casting and block covers up the hole in both instances...?
