A year ago there was a thread about oil pan baffles and at that time I started creating a baffle of my own. After a long period of sitting collecting dust, I've installed the new part.
Maybe it will make an improvement, hopefully it doesn't create a problem.
How's it look? pan image
There are some gaps on the front corners but the center is fitting fairly tight,with a little preloading. Although it's not tight enough to prevent any leakage. The baffle height is even with 4 qts in the sump.
