Project Jensen Healey
Neil907
#1 Post by Neil907 »
After sorting some of the links in my track sprint project I thought I would post the thread to my Jensen Healey project in here incase it interests a few people even though its not Triumph related.
I've had the car for about 15 years and kept it in largely standard spec until now. I have copied the posts from another forum so hopefully it all makes sense.
Time for a change of project, this one even has a deadline so may be completed before I die:cool:
The Jensen has been laid up for about 3 & ½ years, primarily because the valve guides are worn in the borrowed engine that is in it. The proper engine has been in bits for about 6 years since needing a bottom end rebuild.
I dug the car out of the garage a couple of weeks ago and it all looked to be in pretty good nick still. It started first turn of the key after hitting the fuel pump with a hammer and changing the battery, apparently 3 years of trickle charging has boiled it dry :dunno:.
The plan is to get it ready to use for my wedding next year and then to take it to Europe for a few weeks and hopefully hit a trackday or two.
With this in mind the 4spd box is being replaced with the 5spd W58 box from Steves supra.
That was removed last weekend and cleaned up.
size comparison against a spare 4sd I have
It should fit without any need to modify the car but will need to be fitted to a lotus excel bell housing, modified remote, different clutch, modified mounting and either converting to cable clutch or most likely convert the car to hydraulic clutch and a custom prop.
Next will be the engine.
I am currently looking a two possibilities, one is to fit the later 2.2l crank, rods and pistons, different cams and a few other mods to bring the engine up from 140hp to 180ish.
The second option is to just buy a 2.2hc engine and give it a freshen up. The hc engine has a much stronger block but is much wider which means it won't fit without some serious modification.
I will also get a roll hoop fabricated just in case putting cars on their roof runs in the family.
I also need to look at the back axle as there is some play between it and the diff, the perfect time to fit an LSD if only someone made one that fitted.:(
Phase two of the project which will likely be the early part of next year will be to get a couple of small bits of body work sorted, tidy up the couple of doggy bits of interior and decide if the brakes and suspension need upgrading.
If its dry tomorrow the plan is to take it for a little FTP run to see if anything else needs sorting that I have forgotten about
Took a trip to lotus bits in Coventry yesterday with Steve.
Cam back with this lot on the redjet
I have basically bought a complete 900 series engine in bits made up of all the right parts to do what I need.
Second hand parts.
Sump - esprit 907 this has a symmetrical pan so oil performance is the same round right and left bends, is also baffled. The Jensen sump is offset to the left and only has one crap baffle. This will need a slight modification to clear the subframe.
Block- esprit 907 This is the same as the mk2 engine fitted to the Jensen (mine is a mk1) except the tag for the mains are on the opposite side, this is to take the bearings to suit the cross drilled crank. Compared to my existing block this is stronger whilst having a much better breather set up.
Cam carriers - 907 series2 these are the same style as mine but unlike mine have ‘o’ring seals rather than a gasket which sits between the carrier and the head and made shimming a nightmare.
Head studs - Series 2 higher tensile strength.
Pistons & rods 912HC – rods designed to throw oil at the back of the pistons to keep them cool. Higher compression mahle piston. These are of a better quality material than my hepolite ones. They expands less so are a tighter tolerance in the liners which causes less piston slap which the earlier engines suffer from.
Crank – 912HC 2.2 cross drilled crank with fresh regrind -10thou.
Bell housing – Excel long, this will fit the supra box onto the 912 crank
New bits.
Cams – reground Kent L14
Pulleys – HTD pulley set with vernier cam pulleys. The earlier engines had a square belt which were prone to snapping with increased power.
Valves - +1mm lotus bits valves.
Head – CNC ported with freshly cut seats, new guides and a skim. Was planning to do this myself but after seeing a sectioned head and how close the porting takes it to the coolant ways, which seem to vary in postion due to core shift (he recommended buy 3 heads if I was going to do it myself to allow for scrapage lol) plus adding in the cost of guides, skimming & valve seat cutting plus all the time I decided this was the sensible route.
All the servicing items required to rebuild including liners, Bearings water pump & head gasket.
Some of these bits will be being posted later and should be here in about 2 weeks.
On top of this I still need
Decide what do do with flywheel – could use standard one but heavy and aparntly should not be revved over 7,200, could use lighter esprit one but will need redrilling to take the clutch to fit my box. Excell ones are apparently crap so the 3rd option is to buy a lightened one.
Need to buy an excel friction plate & uprated pressure plate.
Need to convert the bell housing to cable operated but at £400 for their kit will probably make my own, he did offer to let me have some dims to make my life easier.
Carbs – for this level of tune I need the spec 9 or 10 45’s. He has some spec 10’s in stock that need a service which he offered at a sensible price, it is probably cheaper to buy these and service the ones I have to sell on, rather than change the chokes and jets in mine. Additionally the spec 10s are tri jetted so have an extra jet enabling better power delivery and maybe slightly better economy.
I also picked up a copy of the engine section for the workshop manual, some engine stands to make it easier to work on, he wanted £80 so is said no and would make my own so he threw them in for free. Was up there for about for about 5 hours in total, very helpful and knowledgeable bloke. All in all a good but expensive day out.
Still waiting for the rest of the bits to turn up, have also ordered an AP racing clutch but that is also delayed due to manufacturing problems. Been concentrating on cleaning all the bits up, have lightened & balanced the gudgeon pins. Have decided to put an MOT on it before I take the old engine out to make life easier when running the new engine in. Took it in this afternoon, went straight through:D but unfortunately broke down 25 yards from home on the main road in the p155 rain, fuel pump decided it preferred resting to working for a living :m:, got that working again, just need to get it registered as historic and get my free road tax:thumbs:.
Turned out not to be fuel pump after all and broke down 4 times in 12 miles last Saturday, swapped the dizzy for a spare. completed 90 trouble free miles today and yesterday. Looks like its the second electronic ignition I have killed in that car now. Should get the rest of the engine parts next week with a bit of luck then can start the build properly.
Car has been behaving itself and has now covered a few hundred miles this year, Weather permitting the engine will be coming out next weekend ready to check the new sump and box fit, before removing the front suspension and subframe for a repaint as it was last done 15 years ago and bits are starting to look a bit tired.
Most of the bits I was waitng for turned up on Monday, Crank with 10thou regrind, lightweight fly wheel,liners, bearings, ported head & carbs.
Heavily machined rear of the billet flywheel.
The head has been ported, chambers machined, vale seats cut and new guides fitted.
I have cleaned and fully rebuilt one of the 45's that I had, just the second one to go. Then these will be up for sale
The new set of tri jet 45's, also in need of a clean and full rebuild.
Cylinder head from the original engine compared to the new ported head.
Current engine removed from the car.
New engine and box laid next to the old one for comparison. Unfortunately it looks like I wont get away with modifying the existing remote so will probably have to get a shorter one and modify that instead.
modified esprit sump clears the subframe nicely
W28 gearbox fits in the tunnel nicely with more clearance than I had expected. Will need to fabricate a new gearbox mount later.
Clutch finally turned up this week, only for the friction plate to be the wrong one:(. Also checked the rad and as I suspected its a standard 2 core one so will either need to get it recored with 3 cores or fit an uprated ally one.
The correct clutch finally turned up last week, only took 4 months:mad:. All of the required parts were delivered for balancing today, should take 7 to 10 days. Head is largely built up now. Liners have been fitted to the block. front suspension & sub frame has all been removed from the car, shot blasted and painted ready for reassembly. need to sort the gear linkage and get the radiator recored whilst I wait for the crank etc to return.
So much for having it back in one piece before the end of the summer:rolleyes:
Front subframe has been fully stripped down , knocked up a temporary shot bllast booth and blasted all the parts.
All primed
All blasted and ready for reassembly
New gear lever remote designed, machined and fabricated, has since been fully welded.
original Toyota one can be seen here, this moves the gear lever forwards about 3.5" which shoul hopefully line it up with the hole in the tunnel.
Cylinder liner clamps machined up, liners lapped to correct nip height and glued in place.
Parts all cleaned ready to go off for balancing.
Sump modified to around my subframe and baffle cut ot modified and made removable.
Went to start building the bottom end up yesterday only to discover that the center upper main bearing shell had the tag on the wrong side, this is due to my shells being for the 2.2 crank which is of a different design to the 2 litre crank which is what my block is from, so I ground out a new groove in the block for the bearing tag.
Balanced pistons and rods all assembled.
Crank fitted and 2 halves of block assembled, pistons were also fitted today.
Went to fit the front crank seal cover this morning and discovered that there was no hole in the block for the cambelt tensioner, if only I had realised before fitting the crank, anyway missing hole drilled and tapped and cover fitted, I guess this is the joys of building a mix and match engine
Few more bits ordered, decided to buy the a spigot bearing and sleeve rather than make an oillite one and the same for the release bearing sleeve, decided time was more important than saving a few pennys.
Block carefully covered up as the crank and pistons were fully exposed and put on the pillardrill to drill off the hole for the cam tensioner.
Cam tensioner stud, front housing and pistons fitted.
Cylinder head, oil pump, rear seal housing, flywheel and clutch cover all fitted.
The Engine is pretty much complete now, Still need to time the cams in, decide on what distributer to use, fit the clutch plate and the ancillaries & rebuild the carbs.
Next is to finish sorting a couple of bits on the body, modify the bell housing to suit the cable clutch, finish rebuilding the front subframe and make the upgraded front brakes fit.
matt of the vivas
Re: Project Jensen Healey
#2 Post by matt of the vivas »
Nice car.
Lots of very familiar parts there, having previously owned a Lotus Excel and Vauxhall Magnum...
Matt.
trackerjack
#3 Post by trackerjack »
Nice work and great car.
wiggybum
#4 Post by wiggybum »
Were you not tempted to drop one of those Lotus engines in your Sprint?Looks superier in many ways to the triumph engine.I really like the split crankcase style around the mains which must make the bottom end very strong and lightweight at the same time.
1981 1500 HL man/od
2007 MX5 Sport
2010 Citroen C1
1993 Gas Gas GT32
Neil907
#5 Post by Neil907 »
wiggybum wrote:Were you not tempted to drop one of those Lotus engines in your Sprint?Looks superier in many ways to the triumph engine.
I briefly considered but I think fitting would be an issue as its leant over a little more and the twin cams gives a very wide top end, also they are not the cheapest engine out there. There are newer and better engines out there if you are going to bother with swapping besides I believe in cars like these the engine is what makes them what they are
wiggybum wrote:I really like the split crankcase style around the mains which must make the bottom end very strong and lightweight at the same time.
You would think but they still suffer, that said they fixed that with the 912 block but the Jensen steering column gets in the way of that hence sticking with the 907 block
Neil907
#6 Post by Neil907 »
Bell housing modified to put the pivot point on the opposite side to convert from hydraulic to cable clutch.
Brackets made up and arm modified.
Gearbox trial bolted to engine and hooked up to spare pedal box to test that clutch fully engages and disengages.
New fuel pump arrived.
Unburied the dolly so that It could be buried even deeper, should now have enough room in the other garage to bring the Jensen up to drop the engine back in and get on with the rest of the jobs.
Wanted to fit some slightly uprated brakes, but more importantly vented front discs as fade has always been a bit borderline on track. Had some princess 4 pots in the shed and they looked like they would fit under the wheels along with some Renault 21 discs that had a usable offset, unfortunately on full lock the calipers foul on the springs so have abandoned this idea for the time being.
Subframe completed and ready to drop back in tomorrow, just need to decide what to do with the brakes, have put the standard on discs back on for now.
Have bought a new dizzy as the advance curve on mine was wrong for the spec I now have. So have bought an accuspark one with no mechanical advance and a magic box that allows the advance curve and dwell to be mapped from a lap top. Not the most sophisticated but should be an improvement whilst still looking fairly standard if I can find some where to hide the box.
#7 Post by tony g »
Nice write up and pictures :) FRont subframe straight from A series manta with added brackets :)
Neil907
#8 Post by Neil907 »
Pretty sure its different to the manta, but is straight out of viva and firenza so very similar
mahony
#9 Post by mahony »
Looking good, there was a sprint a few years back with a lotus twin cam in , think it was fast car it was featured in :)
viewtopic.php?f=9&t=9351
Neil907
#10 Post by Neil907 »
Subframe all bolted back in the car and transported up the road, engine ready to go in.
Was a touch more snug to drop in with the wider sump but slid in nicely, only issue is my new clutch cable bracket is hidden behind the subframe so will have to make another one.
Old mechanical speed vs new electric one, the new smiths one looks similar enough, this means I can use the toyota speed sensor and not need to faff about taking the box apart and finding the right drive gears to match the original speedo.
Radiator was sent away today to have an uprated core fitted, Supra prop nose was also sent off to be made into a new propshaft.
Getting close now but still alot of silly jobs to do and it seems to be fighting me all the way.
Neil907
#11 Post by Neil907 »
Been a while so thought I would update this
Prop and electric fan arrived
Fabricated a new gearbox mount
Engine all ready to run
This was back in November, had all sorts of stupid problems, blew a coolant hose off, my fault for not flaring a pipe, then more cooling issues which turned out to be the rad cap on the new rad not sealing and not allowing the system to pressurise. Then had lots of running issues with dodgy fuel, the new electronic ignition, broken wires on the new speedo. after much faffing it was ready to test drive which showed an oil leak on the pump housing.
The leak was on the gasket face in the above pic. In the end It turned out to be a concave surface on both the pump and the block, after much effort they are now flat and seal nicely, strange as the pump is off the old engine.
Once all this was sorted it seemed to run ok ish, still had a few carb problems.
I then Knocked up am oil catch tank to replace the temporary milk carton. I have made it to look like the oil seperator tank that was fitted to the original mk 1 engine and looks pretty good painted black and mounted on the bulkhead with a new sticker I had printed.
Carbs have been in pieces again and hopefully fixed the problem. Ready to set them up again then off to the rolling road and a geo line up. Enthusiasm has been lacking lately though with all the s##t weather.
maximus
#12 Post by maximus »
Lovely pics, great read too :D
rpgrainger
#13 Post by rpgrainger »
looking good
my mate down the road has two of them in his garage and a Jensen gt
I have two of the engines in my garage for the above cars
I think he also has a complete dash from a gt to fit into his Jensen as well
I will show him this as all his need restoring
rob
