Page 1 of 2
Alternative alternator (sprint) ?
Posted: Fri Jan 09, 2015 7:42 pm
by tony g
Is there an alternator from a modern car that would fit without too much trouble? I was thinking of something like a denso from a Japanese car or similar. I dont mind fabrication/machining bits to suit and as the wiring loom is going to be "modernised" soon I thought I could integrate this at the same time.
Re: Alternative alternator (sprint) ?
Posted: Fri Jan 09, 2015 7:50 pm
by xvivalve
A127 from Montego/Maestro. Fits without any modification.
Posted: Fri Jan 09, 2015 9:08 pm
by soe8m
xvivalve wrote:A127 from Montego/Maestro. Fits without any modification.
Modern. :lol: :lol: :lol: :lol:
There are a lot of "modern" lucas alternators that fit. The LRA100 is the most modern type. If you want a denso or something like that the best is to go to a shop that sells alternators and just have a phisical compare what could fit.
A friend of mine does work at such a shop ands the lra100 is fine. They are also with more amps but i do not know their number. He also did modify some bosch starter for me that fits. Half the current, 1,7kw, double the speed and half the weight as the orignal 0,7kw one.
Posted: Sat Jan 10, 2015 1:27 am
by Jon Tilson
LRA100 style predates the A127...
Guess you dont have too much later Brit stuff in Orange country...
There isnt that much left here....:-)
Posted: Sat Jan 10, 2015 12:25 pm
by tony g
Thanks guys, I'll do some research.
Posted: Sat Jan 10, 2015 12:44 pm
by xvivalve
No, there's not a lot left, but the alternators are still in plentiful supply, even new ones, and as they fit without modification of anything it's an easy way to get 60 - 65 amps.
Posted: Sat Jan 10, 2015 7:11 pm
by tony g
I did know about the montego units as a replacement but I was also thinking of losing the bulk sizewise. With originals so close to the battery (which i'm moving also) I'm trying for a clean look in the engine bay if poss. I may have other plans for the space provided :)
Posted: Sat Jan 10, 2015 7:23 pm
by xvivalve
The A127 are slightly smaller in width and circumference, but not a lot
Posted: Sun Jan 11, 2015 11:24 am
by cliftyhanger
the little denso ones are very good. Daihutsu charade I believe...
Little bit of a fiddle to fit, but I got 2 brand new genuine ones at £40 each. Bargain.
Posted: Sun Jan 11, 2015 12:51 pm
by tony g
Thanks Clive, do you have any pics of your set up?
Posted: Sun Jan 11, 2015 1:56 pm
by cliftyhanger
It was on my 1500, now bolted to a TR7 engine (oops, must get that car finished :oops: )
Can take a pic, but be aware I think my mounting would not be typical. I had no reference to begin with....
But the alternators are tiny, light and about £180 from brise motorsport, used by loads of people in lightweight kitcars etc.
http://www.brise.co.uk/Denso-5305.html
cheaper off the bay...
Posted: Sun Jan 11, 2015 2:50 pm
by tony g
Yes they look good. If the mx5 one i have doesnt work out ill head in that direction .
Posted: Sun Jan 11, 2015 4:08 pm
by GrahamFountain
Thinlk i'm in need of one - haveing it and battery tested tomorow (if it starts).
But these A127 appear to ba available left and right handed:
http://www.ebay.co.uk/itm/BRAND-NEW-ALT ... 35d2ab0f8c
http://www.ebay.co.uk/itm/NEW-ALTERNATO ... 35d2ab158a
Anyone know which fits?
Hmm....
Posted: Sun Jan 11, 2015 4:16 pm
by sprint95m
cliftyhanger wrote:It was on my 1500, now bolted to a TR7 engine (oops, must get that car finished :oops: )
Chris Witor sells these as kits ready to fit our cars....
http://www.chriswitor.com/proddetail.php?prod=CW4595
Posted: Sun Jan 11, 2015 4:29 pm
by cliftyhanger
My £40 sounds a bargain! The spacer for the mount was just washers, a few, but easy to get it exact. The adjuster I cut and welded the standard arm. But those turnbuckles are not too dear. On mine, I ended up using a 2CV belt (no manual fan)
