headlight bowl seals..
Posted: Fri Feb 06, 2015 10:17 am
by Dollyby 2
Hi folks.where can one get the seals that go behind the
Headlamp bowls..thanks.Myles.
Re: headlight bowel seals..
Posted: Fri Feb 06, 2015 11:26 am
by Magenta Auto Sprint
are you talking round head lamp seals?
I have a set of four, I think they may be new, £5 +postage?
regards
Malcolm
Posted: Fri Feb 06, 2015 7:44 pm
by Dollyby 2
Hi Malcolm.I Should have been more
specific. It is the
round
headlight model.the seals in question are
fixed to the headlamp panel and the bowel protrudes through it,hope that makes more sense,Myles
Posted: Fri Feb 06, 2015 10:18 pm
by Flyfisherman
Dollyby 2 wrote:Hi Malcolm.I Should have been more specific. It is the round headlight model.the seals in question are
Like these
http://www.jamespaddock.co.uk/PartImages/511602.jpg
Paul
No,......
Posted: Sat Feb 07, 2015 10:48 am
by sprint95m
No not they ones, it is the ones for the bowls that the OP is asking for.
The ones he wants are used on Dolomites but not Stags or T2000s.
I may have one or two of those....I will check and let you know tomorrow.
If I do, it is free of charge, you can use one as a pattern to make copies (out of s/h inner tube rubber, maybe.) if necessary.
(There was a thread some time ago where Mark (
memberlist.php?mode=viewprofile&u=142)
had some made in EPDM rubber.)
Posted: Sat Feb 07, 2015 5:56 pm
by Dollyby 2
Hi folks,sorted made them from sheet rubber,they go on the inside panel of the outer bowel.held on by two halfmoon plates,thanks again all,Myles
Posted: Sat Feb 07, 2015 10:22 pm
by Flyfisherman
So its the inner headlight seal - like these then.
viewtopic.php?f=19&t=25122&start=135#p249520
Paul
Re: headlight bowl seals..
Posted: Sun Feb 08, 2015 6:36 pm
by Dollyby 2
Hi Paul,yes those are the seals, I made them up from some rubber sheet. Myles.
Yes...
Posted: Mon Feb 09, 2015 8:21 pm
by sprint95m
Glad you have got it sorted Myles.
I do indeed have a bowl seal that is suitable for using as a pattern, also found a good bowl too.
(I made a box for behind the outer headlamp, thereby removing the need for bowls and seals.
To form mud shields I simply used sides from plastic containers.)
Posted: Mon Feb 09, 2015 11:13 pm
you mean part number 627243, I had to make mine too.
I used a tool that I bought from a craft shop, a scapel on a compass, makes cutting circles very easy.
At least you're sorted now.
malc
