Fuel line size questions
Posted: Thu Feb 26, 2015 1:48 pm
Hey all,
So I'm replacing my fuel lines as they're old and dried out. I'm done to the fuel pump, but now I have a question. The fuel pump outlet is 5/16, but the HS6 inlets are 1/4, what's the best way to connect the two sizes? Should I simply use a reducer barb and then T off the two fuel lines or should I use a 5/16 T and then reduce the size before each carb with a reducer each? Originally the 5/16 hose was double clamped to the 1/4 metal fuel line going to each carb, but that didn't seem like the best solution even though the car has been running for years with it. Any thoughts? What is your setup between the fuel pump and carbs? Thanks guys.
