Measuring Rear Hub End Float
Posted: Mon May 04, 2015 7:18 pm
by SprintMWU773V
I need to measure the end float on my rear hubs. Looks like a I need a dial indicator to do this but virtually all the stands I have seen are magnetic and I cannot see how this would be useful due to the shape of the backplate. I have seen one which you basically bolt to the hub but alas it was in a video rather than actually for sale.
The one I have seen can be seen in this picture
https://www.prod.facebook.com/trailerfi ... 3868121193 but Paddocks no longer sell one.
Any ideas on the best way to measure the end float or perhaps where I might get such a mount for a dial indicator?
Re: Measuring Rear Hub End Float
Posted: Mon May 04, 2015 8:27 pm
by soe8m
A magnetic one is the best to buy because you can use it for many purposes. If it does not clamp enough on the backplate you can clamp a piece of iron with some grip pliers to the backplate first.
Posted: Mon May 04, 2015 10:52 pm
by Dolly-Nut
I found after driving the car the clearances totally change anyway.
Posted: Wed May 06, 2015 7:15 pm
by PaulB
Hi Mark,
Why can't you clamp the dial gauge mount to the backplate?
http://www.ebay.co.uk/itm/Quality-0-10m ... 20e7927554
I have also used a heavy steel plate placed next to the axle and clamp the magnetic base of the dial gauge stand to it. It heavy enough not to move. You are welcome to borrow some bits if it helps.
Posted: Wed May 06, 2015 9:21 pm
by SprintMWU773V
I wasn't sure it would work. However I should be picking up a dial indicator and magnetic stand tomorrow so I should be able to find out! I think on reflection I will be proven wrong and should be able to work it all out without too much difficulty.
Posted: Wed May 06, 2015 9:50 pm
by James467
Mark, I have the machine mart one and managed to mount it to the area that the cylinder sits.
Posted: Wed May 06, 2015 9:57 pm
by tony g
Why not mount the mag part to the hub end and put the probe onto the back plate? Same movement.
Posted: Thu May 07, 2015 5:16 pm
by SprintMWU773V
Well I've had a tinker with my new tool this afternoon. First impressions are that it easily fits where it needs to which is good. I'm not 100% happy with my shimming yet but don't think it's too far off.
I've had to swap one half shaft as it had the smaller earlier studs on it. Fortunately i had a spare one and even more handy was it was the same hand. I know they're not handed but I have heard suggestions that it might be better not to swap them from side to side.
How many shims?
Posted: Thu May 14, 2015 9:20 pm
by SprintMWU773V
So how many shims have people typically used? The one side I have done took one thick shim of about 0.8mm to achieve 0.012mm of end float. Contrast with what I took off which seemed quite a lot, probably about 1.6mm. Unfortunately I forgot to measure the end float on either the original axle or the one I am using but both had a number of different shims on them.
Either I've done something wrong or the person who set it up before didn't know! I can't see how you can get it wrong but there you go. If you over-shim you just end up with loads of movement surely?
