rear axle bushings 1850
Posted: Wed May 06, 2015 6:50 pm
Hi all, I'm finally getting some enthusiasm back for the dolly. Just before the road tax ran out it late last summer it developed a judder/bang on pull off. With some gentle throttle and clutch it would still pull off but under normal driving, it became a worry.
I posted at the time and I was advised to try the rear axle bushings. Having a quick look today I'm a little unsure which bushings to order and replace. The rear suspension arm bushes don't look in great shape so ill replace these anyway, but should I also do the radius rod bushes? These look ok but I just wanted to confirm which are the usual cause of the judder issue.
Also, there's been a slight loss of fluid from the centre of the rear axle, only an occasional drip on the carpet but ill change the diff oil as well to rule that out.
Any advice or pointers appreciated.
