Idling ?
Posted: Sun May 17, 2015 9:01 pm
Hi all
I have now had my 1978 sprint now for about 10 months and enjoy every minute of driving it.
Today I gave it a service changed and topped up the fluids renewed the oil and air filters and adjusted the timing to 16 btdc, which has made it pull and drive a lot better and it fills crisper to drive.
The thing is that I cannot get the idling below 1000 rpm, I have wound the idle adjustment screws right up so they are not touching the linkage and also slacken off the choke so this is not affecting it.I have had this fault since I purchased the car.
I run the car on Shell V power petrol , I hope you can help me solve this fault because apart from this it drives great.
I have set the ignition as below:-
16 btdc
Spark plug gap 40 thou
Standard air filter
Piranha electronic ignition
I also have a vacuum gauge fitted and at idle (1000rpm) it reads23.
16 btdc
Standard air filter
