Rear Brake Cylinders.
Posted: Tue May 26, 2015 8:57 pm
by Phil Huskinson
Help Please.
I have a Dolomite 1850 HL 1980 model. Rimmer's have listed 2 rear brake cylinders part no. GWC 1502..... and GWC 1121 also says 5/8 inch.
My Comm number is WF 83840 H . Is the correct part GWC 1121. the same for a Sprint I think. Has anyone out there fitted cylinders on a 1980 model. Would appreciate help.
Re: Rear Brake Cylinders.
Posted: Tue May 26, 2015 9:00 pm
by Edin Dundee
Hi Phil,
Can't help I'm afraid, but I would suggest posting this on the main forum.
Okay.....
Posted: Wed May 27, 2015 10:26 am
by sprint95m
Phil, as long as it is a matching pair you can use either, however, if it was up to me
I would use the earlier GWC1502 because these are a smaller bore, which will give a better brake pedal feel.
Posted: Wed May 27, 2015 2:01 pm
by Jon Tilson
Dont you have to use the smaller bore with the dual circuit master?
Posted: Wed May 27, 2015 4:38 pm
by Richard the old one
I also believe that you have to use the smaller diameter brake cylinders with the dual brake system.
Posted: Thu May 28, 2015 9:32 pm
by gmsclassics
Yes, I can confirm that you must use the smaller diameter with the dual circuit system. Otherwise if you lose the front system, the rear doesn't stop you.
I understand the larger bore was fitted to single circuit systems, but was changed with the introduction of the dual circuit braking system. 1850 will be the same as the Sprint.
Geoff
