Petrol pump mystery
Posted: Tue Sep 29, 2015 8:52 am
Took my Toledo to a show on sunday at Beamish museum, lovely weather and a massive turnout... but the little Triumph decided to die once i arrived.
Turned out the float bowl was completely empty and the pump wasnt delivering, its the older type with the little primer handle underneath and pushing this made a bit of a wet squeaky sound from the pump and still wouldnt draw fuel in. so with a modest amount of spares available i decided to swap the diaphragm, it fired up after that and got home without any issues, However.... the diaphragm i took off the car looked fine so one home i swapped it back and the pump worked fine... i can only think perhaps a stuck valve (they are only a few months old as i renewed them) or some sort of bloakage. I wondered if anyone had any other ideas/suggestions? im just concerned that it has the potential to do it again.
cheers!
cheers!
