1300 FWD engine
Posted: Tue Nov 10, 2015 9:17 am
by Dumbledorbin
Long shot, but does anybody have a 1300 FWD engine I could buy off them? mine died an unfortunate death on the weekend.
Re: 1300 FWD engine
Posted: Tue Nov 10, 2015 7:03 pm
by Triumph1300
Where are you based?
Re: 1300 FWD engine
Posted: Wed Nov 11, 2015 1:08 pm
by Dumbledorbin
Based in chester
Re: 1300 FWD engine
Posted: Wed Nov 11, 2015 5:57 pm
by Triumph1300
What's happened to your existing engine?
I've got an engine and box here, minus head, and timing gear, but it's an unknown quantity.
I acquired it a few years ago, it's been sat in the garage ever since.
Re: 1300 FWD engine
Posted: Wed Nov 11, 2015 6:07 pm
by Toledo Man
Whatever the problem is, you've come to the right place. Seek a second opinion before condemning your engine.
Re: 1300 FWD engine
Posted: Thu Nov 12, 2015 9:09 am
by Dumbledorbin
Engine is seized. taken head off. can not turn over by hand. little bit of sideways movement in all the pistons and no scoring on the cylinders so guessing they should be all good. so bottom end damage im assuming.
Re: 1300 FWD engine
Posted: Thu Nov 12, 2015 8:19 pm
by Triumph1300
Hmmm, seized when you were driving, or after standing?
Stupid as it sounds, is there no movement on the crank at all, either rotational, or fore/aft?
The engine in Coventry turns nicely
Re: 1300 FWD engine
Posted: Fri Nov 13, 2015 11:08 am
by Dumbledorbin
It seized while driving. I wasnt driving at the time but hey ho. Not too impressed to say the least. Is it possible to take engine out and leave gearbox in situ?
Re: 1300 FWD engine
Posted: Fri Nov 13, 2015 12:36 pm
by Toledo Man
The block can be removed leaving the gearbox in situ. It should be a bit lighter with the head off. Have you made any attempt to free the pistons? It might be better to try this with the engine out of the car anyway.
Re: 1300 FWD engine
Posted: Fri Nov 13, 2015 1:35 pm
by Dumbledorbin
Pistols have small sideways motion but no up or down. Just need to get the engine out. But sourcing a crane is proving difficult. A couple of us should be able to lift it by hand though I would have thought?
Re: 1300 FWD engine
Posted: Fri Nov 13, 2015 3:55 pm
by Dumbledorbin
Okay. Need new block crank and pistons.
Re: 1300 FWD engine
Posted: Fri Nov 13, 2015 7:12 pm
by Triumph1300
As before, block etc here in Coventry, I would recommend rebuild before fit, currently attached to a good gearbox, but can be split off.
Make me an offer
Re: 1300 FWD engine
Posted: Fri Nov 13, 2015 7:34 pm
by Dumbledorbin
I have no idea what it's worth. What do you want for it?
Re: 1300 FWD engine
Posted: Sat Nov 14, 2015 7:37 am
by Triumph1300
Offer me Fifty quid, it's yours
Re: 1300 FWD engine
Posted: Mon Nov 23, 2015 1:56 pm
by Dumbledorbin
Sounds good to me. PM coming your way
