Steering U/J ?
Posted: Tue Dec 01, 2015 8:15 pm
by Steve28
The steering U/J at the bottom of the column on the toledo needs replacing due to play in it, just wanted to know if its the same joint through all the ranges as ive got some spare dolomite/sprint ones.
Re: Steering U/J ?
Posted: Tue Dec 01, 2015 8:25 pm
Yes they are all the same, in fact it is the same joint on the Herald/Spitfire range too!
Re: Steering U/J ?
Posted: Tue Dec 01, 2015 11:21 pm
by Jon Tilson
Flexible coupling yes...u/j is not the same as a Spit/Herald one for sure...Spit shaft is a lot longer.
Toledo and dolomite intermediate shafts are all the same...
Re: Steering U/J ?
Posted: Wed Dec 02, 2015 12:22 am
Jon Tilson wrote:Flexible coupling yes...u/j is not the same as a Spit/Herald one for sure...Spit shaft is a lot longer.
Well he did say the one at the BOTTOM of the column Jonners!
Re: Steering U/J ?
Posted: Wed Dec 02, 2015 9:31 pm
by Steve28
Thanks for the replies,
Well today we had a good look by taking them both off to find out its the upper U/J that's gone the one that fits on the bottom of the column, we have a choice of two good S/H ones to fit, one is original type and the other looks like an after market one.
steve
Re: Steering U/J ?
Posted: Wed Dec 02, 2015 9:57 pm
by Karlos
How come the silly bottom joint is called a UJ by so many of us, surely the pedants among us must be bursting blood vessels!!!
The "bottom" one is not a UJ, it is an inline joint that is used to connect the intermediate shaft with the rack, it also is there to absorb minor vibrations and shock.
"Flexible coupling" is a better term ,especially when the rubber bushes are failing - it then becomes very flexible. The top one is definitely a UJ
Re: Steering U/J ?
Posted: Wed Dec 02, 2015 10:04 pm
by geeksteve
To avoid all confusion we should call the top one 'the UJ', and the bottom one 'the liability'
Re: Steering U/J ?
Posted: Thu Dec 03, 2015 10:25 am
by Jon Tilson
Lol Steve of all people should know the difference between a u/j and a flexible coupling....
And I'm not sure about it being a "liability". If your top u/ seizes in one plane I reckon that's more of a liability...
In short order it will make mincement of the column lower bush and the flexible coupling too....
Re: Steering U/J ?
Posted: Thu Dec 03, 2015 5:55 pm
by matt of the vivas
If we want to be really, really pedantic - Jonners standard
- then the lower one is a Layrub Coupling.
Re: Steering U/J ?
Posted: Fri Dec 04, 2015 5:42 pm
by Karlos
Haha. Who makes up these names?
Re: Steering U/J ?
Posted: Fri Dec 04, 2015 6:29 pm
Its a very old name, goes back to the days of Laycock Transmissions and Clutches...
Re: Steering U/J ?
Posted: Sat Dec 05, 2015 1:01 am
by Steve28
I have fitted the non original U/J and fitted the poly bushes on the steering rack and completely transformed the steering, it make you realise how vague the steering had become.
Re: Steering U/J ?
Posted: Sat Dec 05, 2015 11:40 am
by AlanH
Interesting to know the name of the joint Matt. I have never been convinced about replacing it with a U/J , it's obviously not one.
I assumed that it had something to do with cushioning the steering.
However I know that many people have used a U/J and it seems the compatible replacements are not exactly top quality.
Re: Steering U/J ?
Posted: Sat Dec 05, 2015 12:30 pm
by GrahamFountain
Karlos wrote:How come the silly bottom joint is called a UJ by so many of us, surely the pedants among us must be bursting blood vessels!!!
As something of a professional pedant, I have to say that my "bottom" one is a UJ, and a forged one too.
Not only better than the fake FAM1718s, like below around, but safer by far.
Don't it worry you when a vendor can't even be bothered to find a picture of one that's not rusty?
Re: Steering U/J ?
Posted: Sat Dec 05, 2015 12:50 pm
AlanH wrote:I have never been convinced about replacing it with a U/J , it's obviously not one.
Me neither - its meant to provide some cushioning, not flexibility like a UJ. Layrubs are used to stop vibration, not provide variation in angle like a UJ.
