Do early Sprints have the plastic insert that goes around the screen in the rear screen rubber
Does anyone have a cross section of the insert , as I have a Ford roll and not sure if the same ?
Many thanks
Rear windscreen plastic insert
Re: Rear windscreen plastic insert
My 1975 one does, and if it wasn't like a summer's day on Shetland out there at the minute I'd take a picture for you.
If your Ford stuff isn't right, you can buy the beading from Rimmers. http://www.rimmerbros.co.uk/Item--i-613960
Hi,
Thanks for the reply and info
My 1974 Toledo, my 1977 Dolomite 1300 and all my FWD cars didn't have the trim strip. My 1975 Sprint and my 1850 both have it.
All Sprints had the finishing strip.
I get mine from Phoenix Supplies. 7 metres will do the front and back.
http://www.phoenixtrim.co.uk/
Part no. PT 11 £1.90 per metre.
Many thanks for the replies
I think the triumph insert is " T " shaped as my ford trim is flat
Thanks again
Simon
Thanks again
Simon
