Alloy Carb Mounts
Posted: Tue Feb 02, 2016 7:19 pm
by Mad Mart
Looking at Rimmers website the part no. for both the Sprint and TR7 carb mounts is the same (TKC1338A).
Question is, would the club Sprint alloy carb mounts fit a TR7?
Martin
Re: Alloy Carb Mounts
Posted: Tue Feb 02, 2016 9:21 pm
by triumphdolomiteuk
TR7 carbs: HS6 1.75". Sprint: HS6 1.75" - if the carb body is the same, then it should fit....but...?
Posted: Tue Feb 02, 2016 9:36 pm
by xvivalve
I believe they would.
I believe the spacing of TR7 carbs is slightly wider and the dash pots are taller, but the body of the carbs are the same.
Posted: Sat Feb 06, 2016 8:33 am
by PaulB
Where can I get Sprint alloy carb mounts?
Posted: Sat Feb 06, 2016 8:34 am
by tony g
Club spares
Posted: Sat Feb 06, 2016 4:51 pm
by dursley92
triumphdolomiteuk wrote:TR7 carbs: HS6 1.75". Sprint: HS6 1.75" - if the carb body is the same, then it should fit....but...?
No buts , the carbs are the same and interchangeable. Only difference is some Sprints have a lower dashpot but the mounts are all the same.
I am using the club alloy mounts on my Sprint engined TR7. Excellent.
