Voltage Stabilisers
Posted: Sun Feb 21, 2016 10:52 am
On another thread you'll probably be fed up with my questions about low gauge readings. But I feel this is a question that is sufficiently separate to warrant a separate thread.
When testing the output from the "new" voltage stabiliser, it read a solid 9.7 volts. Later I decided to clean up the old (not sure its the original, though) VS and see what volts it put out, only to find I couldn't read it, because it was pulsing. However, it gave a slight gain in the gauge readings, which is a good thing. (I assume it's more than 9.7v)
Because of this difference, I did a little research (yes, I know a little knowledge is dangerous) and found that Smiths VS's were a bi-metalic set up and were designed to pulse.
Why then doesn't the new one pulse? Is it a newer design and not meant to, or is it a dud?
Cheers,
Rob
Cheers,
Rob
