HELP - Sprint engine sitting too high
Posted: Tue Mar 01, 2016 8:49 pm
by simonhorton
I've put the engine back in my car , and the engine seems to sit too high
When looking across the wings , the oil filler cap is higher than the top of the wings ?
Is it possible to fit the rubber mounts upside down ??
Any help much appreciated
Thank you
Re: HELP - Sprint engine sitting too high
Posted: Tue Mar 01, 2016 10:14 pm
by Flyfisherman
simonhorton wrote:I've put the engine back in my car , and the engine seems to sit too high
Thank you
Simon
Rubber mounts no - but engine mounting bracket yes - there is a slot cut out (half a circle) in the bracket these should be facing upwards and be nearest to the radiator. As for the brackets the largest (in size) should be on the nearside and the smallest (in size) on the off side .
See attached picy.
So the bracket on the right hand side of the picture fits on the off side and the other on the left hand side of the picture fit on the near side.
Paul
Posted: Wed Mar 02, 2016 7:17 am
by simonhorton
Hi Paul,
Thanks for the reply
I have my metal engine mounts the correct way around and on the correct sides
Is it possible that the rubbers studs are slightly offset from centre were the studs go through the engine mounts
IE - if you turn the rubber mount around 180 degrees the studs would be higher / lower than the centreline ??
I'll try and send a pic later today
Many thanks Simon
Posted: Wed Mar 02, 2016 8:27 am
by Tony Burd
Are you sure it is definitely higher, have you put a straight edge across it?
I thought mine was when I first looked, the filler cap ends up in one of the recess parts of the bonnet, it is very close, my bonnet has press lourves in that area & I can see how close the cap is, will try & get a picture for you.
Otherwise have you fitted new engine mounts, there has been some talk on here of them being very hard, so maybe they are not sagging as much as the originals, if so try putting the old ones back on.
Have you got the engine steady bar fitted to the exhaust manifold bracket, did that fit ok?
Posted: Wed Mar 02, 2016 11:28 am
by xvivalve
I second what Tony says above; take a bonnet off any Sprint and you wonder how it didn't interfere with the filler cap!
Posted: Wed Mar 02, 2016 9:14 pm
by Sundowner
xvivalve wrote:I second what Tony says above; take a bonnet off any Sprint and you wonder how it didn't interfere with the filler cap!
I hope this photo of my half naked SPRINT helps...
Bonnet off, radiator out, bible on the roof, tools everywhere.....while I was replacing that %#@*&! Rolon tensioner.
Cheers,
Rob
Posted: Wed Mar 02, 2016 9:45 pm
by Tony Burd
