Sprint VA15234 DL
Posted: Fri Mar 04, 2016 12:51 am
We finally got to pick up the Sprint in October 2015 from Millicent in South Australia and the journey was a great weekend away and the Jeep with it's new heads preformed great not missing a bet , as for the Sprint it is now under restoration .
Since starting to resto I have found lots of rust , mostly the fire wall and cowl panel , the nose panel also accident damage to the nose and radiator support panel and front guards lower rear section , at this stage I have cut out the rust in the top of both door pillars and lower windscreen pillars and replaced the cowl panel with a better used item once the rust was repaired as the old one was to far gone and I am working on the fire wall above the gearbox and to the left of the gearbox tunnel .
Cheers will post pics soon .
Larry
Larry
