Page 1 of 2
Recommended Sprint front brake upgrade.
Posted: Sun Mar 06, 2016 1:27 pm
by sprintchris
Hi,
At some point I need to upgrade the front brakes on my Sprint. I see the Trackerjack upgrade seems popular, can anyone confirm if they are readily available and contact details.
Thanks in advance,
Chris.
Re: Recommended Sprint front brake upgrade.
Posted: Sun Mar 06, 2016 5:48 pm
by Toledo Man
Trackerjack is the forum name of the guy who developed this brake upgrade. It is basically VW Gold discs what are machined to fit the Dolomite hub along with Ford Sierra calipers. I suggest that you send him a PM.
Posted: Sun Mar 06, 2016 5:51 pm
by richard4040
Very readily available. Drop him a pm on the forum and I'm sure he will get back to you. Then you end up with this pretty lot:D
Posted: Sun Mar 06, 2016 6:54 pm
by Boost All The Dollys
richard4040 wrote:Very readily available. Drop him a pm on the forum and I'm sure he will get back to you. Then you end up with this pretty lot:D
Is that a front or rear brake kit, only ever heard the trackerjack kit talked about in rear kit
Posted: Sun Mar 06, 2016 6:58 pm
by richard4040
Front. No rear conversion that I know of.
Posted: Sun Mar 06, 2016 7:03 pm
richard4040 wrote:Front. No rear conversion that I know of.
Does it re-use the standard callipers or bigger callipers. There's a 4 piston calliper I found once but I lost the link to it
Posted: Sun Mar 06, 2016 7:05 pm
by richard4040
It is golf mk2 discs redrilled to suit. The brackets are conversion from the standar callers to Sierra 2.0 litre calipers. Then spacers for the back of the discs.
Posted: Sun Mar 06, 2016 8:58 pm
richard4040 wrote:It is golf mk2 discs redrilled to suit. The brackets are conversion from the standar callers to Sierra 2.0 litre calipers. Then spacers for the back of the discs.
Do they fit under standard sprint alloys? I've only heard in passing of the trackerjack kit
Posted: Sun Mar 06, 2016 8:59 pm
by richard4040
Yes:) they are the only conversion that fit perfectly under sprint wheels:)
Posted: Sun Mar 06, 2016 9:00 pm
richard4040 wrote:Yes:) they are the only conversion that fit perfectly under sprint wheels:)
Might give him a shout then
Posted: Sun Mar 06, 2016 9:15 pm
by richard4040
Sure he will be happy to help:)
Posted: Sun Mar 06, 2016 9:22 pm
by Sundowner
Incorrect.
They may be the only
UK conversion that fits inside Sprint wheels.
Here in these antipodese, this "Sprintparts" conversion is the only way to go, but unless you wanted to pay considerable carriage costs, the Trackerjack product would definitely be your best UK bet.
http://www.sprintparts.com.au/products. ... 480198.htm
Cheers,
Rob
Posted: Sun Mar 06, 2016 9:28 pm
by richard4040
Cheers rob. I stand corrected:)
Posted: Sun Mar 06, 2016 10:30 pm
by Sundowner
richard4040 wrote:Cheers rob. I stand corrected:)
I could have worded my post better Richard.
Sorry.
Your advice in the past has helped me lots and I'm grateful for it.
Cheers,
Rob
Posted: Sun Mar 06, 2016 10:50 pm
by Maidstonerob
Is there an adaptor for the Dolomite brake pipe union and the Sierra caliper
