It never rains....
Posted: Tue Mar 08, 2016 6:50 pm
but it pours....
Decided to resurrect the Sprint today after its salt free winter rest. Lots of churning and of course won't start. Petrol in front float chamber? Check....
Ah - last year I stuck it back on a ballasted coil to save the points (lol) after an el cheapo leccy ignition went down after umpteen years. So I put the flying ballast bypass wire on the coil terminal and....whats the smell. Twit you put it on the - terminal and not the +. Quickly corrected but the persistence at not starting means the damage is done.
You forget how much of a git it is to do the points on a Sprint dizzy. Sure enough the insulator is fried and the points look a fine shade of black. It all comes out with the condensor too as I cant get the connector off the melted insulator. And I'm supposed to be some sort of expert doh!
Dive into the garage and sure enough there is my ignition bits shoebox - under about 4 others! But things look up as I discover Reg's old set of points and condensor in his Aldon Ignitor ignition box. This of course won't fit a Sprint cap so now sits in my TR7 powered dolly with a Spit cap and Sprint dizzy, but that's another story. Reg bless him has to have his proper yellow one looking the business, so went magnetronic. I'm far too much of a cheapskate for that...and now its paying off - in wasted time!. Anyway ten minutes later and the new (old) points etc are in and gapped. Its a right pain getting it on the cam - fanbelt pulls to no avail so we bump it in top gear. At least you can see the cam on a Sprint dizzy. Good luck with that on the AC delco one. At least the brakes aren't stuck on.
So flying lead on the right side and a quick squirt on the starter and she fires up first time...sounds lovely with the new
proper sprint sideways exhaust too.
Warm up and all's well....into gear - err no chance there then. Clutch plate is sticking to the flywheel. Having had to bounce it down the road last year I wasnt expecting it to stick again so quickly. But no...its not playing ball. I try the usual in an out of top gear and starter etc...its not having it. And I only moved it about a month ago? Or was it 6?
So with no mates around to give me a push down the road I give up. Then I notice that tell tale patch of wet something or other under the car as I glance down from swapping out the Spit battery. Oh dear that's coolant and yes its coming out of that familiar slot behind the alternator. What! I only did the pump 2 years ago.....or was it three. Anyway far too recently....
Grrr...at least it wasn't freezing cold, but this Sprint isnt going back on the road any time soon by the looks of it.
So the moral is - use them or fix them. I suspect none of this would have happened if I'd just kept driving it all winter!
