Spring Lengths?
Posted: Sun Apr 03, 2016 10:33 pm
by xvivalve
Any one know what the measured free length of standard front and rear springs are?
Okay.......
Posted: Mon Apr 04, 2016 11:15 am
by sprint95m
I have a new pair of front springs for an 1850 or a Sprint, part number 217989,
their free length is 344mm.
Re: Spring Lengths?
Posted: Mon Apr 04, 2016 1:51 pm
by MIG Wielder
...... and I've just found a pair of new, unused " 218324 Rear Spring STD for an 1850 "
L = 295 mm
ID = 70 mm
OD = 91 mm
9.5t of 5 mm wire
HTH,
Re: Spring Lengths?
Posted: Mon Apr 04, 2016 6:27 pm
by xvivalve
Thanks Guys, both very helpful in identifying some of Ted's stuff.
Re: Spring Lengths?
Posted: Tue Apr 05, 2016 9:06 am
by cliftyhanger
Not directly relevant, but I found my ancient TT manual, and it has some specs listed. Worth noting are the shock seat pan dimensions:
Front spring 139lb, fitted length 9", shock pan height: sprint 6.75", std 6.375" (weight on each spring 630lb)
Rear spring 139lb, fitted length 8" shock pan height sprint 6.375", std 5.75" (weight on each spring 500lb)
I reiterate, these are from the original TT manual, so may (or may not!) be reliable. But it seems very plausible that the shocks should be different. The weight on each spring I have calculated from the earlier free lengths, and using the TT figures. Handy to work out free lengths and poundage of springs if you require ant given fitted length.
