random cracks in body work
Posted: Fri Jun 10, 2016 10:35 am
by Boost All The Dollys
I noticed a while back that my dolomite has cracks at the join between the outer front wing and the body panel under the windscreen.
I also noticed that they can sometimes be wider after driving, maybe a credit card wide I think was the widest, what would cause this???
bad join to the body shell??
Re: random cracks in body work
Posted: Fri Jun 10, 2016 10:59 am
by geeksteve
Have you got a photo? There should be a panel gap there right? If you dont have one someone has probably fillered it..
Posted: Fri Jun 10, 2016 11:49 am
geeksteve wrote:Have you got a photo? There should be a panel gap there right? If you dont have one someone has probably fillered it..
I resprayed the car last year and there was filler in that gap, its not like a panel gap, its like someone didn't attach the wing properly and its flexing with use, ill get a picture up later if they are still there.
Posted: Fri Jun 10, 2016 7:50 pm
by 80Sprint
The gaps vary, even on the same car each side but there should always be a gap with no filler in it between the front wing and the windscreen surround. You don't want water trapped in there.
Posted: Tue Jun 21, 2016 2:33 pm
80Sprint wrote:The gaps vary, even on the same car each side but there should always be a gap with no filler in it between the front wing and the windscreen surround. You don't want water trapped in there.
ok, looks like ill have to get it removed then, as there's filler to blend the wing into the A pillar, thank for the heads up
