Brit part module sprint which rotor arm
Posted: Sun Jul 17, 2016 7:34 pm
by cleverusername
I want to go the Brit part route with the dizzy, I have an ambassador cap on order so it will fit. Do I use the normal Sprint rotor arm, or fit a different one if I do this?
Re: Brit part module sprint which rotor arm
Posted: Sun Jul 17, 2016 8:10 pm
by tony g
You use a smaller one. It may be ambassador too but cant confirm that. Looks like a normal small lucas rotor ie mini etc
Posted: Mon Jul 18, 2016 12:19 am
by Toledo Man
I use the Lucas 45D4 rotor arm in my Sprint dizzy under a 45D4 cap. The Britpart kit is designed for the 45D4 dizzy but works in the 44D4 dizzy the Sprint has.
Posted: Mon Jul 18, 2016 10:30 am
by cleverusername
Thanks I have one of those lying around, so that makes life a bit easier.
Posted: Mon Jul 18, 2016 12:02 pm
by Jon Tilson
Yes but this doesnt work with the Sprint manifold IIRC. You need the amby cap to turn the leads clear and I think this has a taller than mini rotor...
I too have used the Sprint dizzy like this with std min/spit cap but in an 8valve slant and not a Sprint.
