Sprint rear brakes?
Sprint rear brakes?
Are Sprint rear brakes bigger than the 1300/1500 brakes? Might consider an upgrade if they are
Re: Sprint rear brakes?
Oh yes, it came from the bigger Triumph 2000 and was in fact so big that they had to put a pressure limiting valve in to stop lock up.
Well.......
To be precise, the Sprint's back brakes were used first on Fords (Cortina mark 2 1600GT and E, 3 litre Capris.)
The linings are interchangeable with the T2000 mark 2 range but the shoes (springs and wheel cylinders) are not.
So, does that mean it stops better than the 1500 brakes? Are the fronts different too?Galileo wrote:Oh yes, it came from the bigger Triumph 2000 and was in fact so big that they had to put a pressure limiting valve in to stop lock up.
No, the fronts are the same across the range.
It would need side by side comparison, but you may be able to fit Sprint back plates, shoes and drums to a smaller axle, but I'd personally fit the balance valve to the floor pan also.
Be aware, Sprint shoes currently in limited supply, Ford folk like Burton sell them for Cortina and Capri, but at £75 a set.
So, the Ford drum brake back plates are similar, but everything else is different? Therefore, it would be cheaper and easier to fit Capri rear brakes than sprint rear brakesxvivalve wrote:No, the fronts are the same across the range.
You can fit larger rear brakes but then you have to reduce the brake pressure to the rear to have the same brake power you already had with the std drums. You have to upgrade the front.
And there speaks the common sense, stop messing around with the rears and change the fronts if you want to stop quicker, it's simple science!soe8m wrote:You can fit larger rear brakes but then you have to reduce the brake pressure to the rear to have the same brake power you already had with the std drums. You have to upgrade the front.
As to Sprint shoes being in short supply, seem to be no problem with availability that I can tell, recently bought a set from Rimmer for £45 but also listed on plenty of other sites?
I have the following cross reference for UKC1254 if it's useful to know:
Size 228.6 x 45mm
Delphi LS 1064
Lucas GS6063
Matec 203
LPR 01170
Unipart GBS780
Simer S241
The T2000/T2500/TR7 parts number GBS796 and GBS813 do not cross reference.
Applications:
Sunbeam
Alpine 1.2 MK V, Sport, GT 65-70
Ford
Capri (69-78) 1.3 GT, 1.6GT
Capri (69-78) 1.7 GT 71-09/72
Capri (69-78) 2.0 GT, 2.3GT 09/69-12/74
Corsair 1.7 10/65-70
Corsair 2.0 E, V4 10/65-70
Cortina 1.6 GT, E MK I, MK II 10/67-07/70
Cortina Lotus 10/67-07/70
Escort (67-74) 1.6 Twin Cam 01/68-09/70
Escort (67-74) 2.0 Mexico 11/70-11/74
I didn't say they were in short supply, I said they were of limited supply, ie only available from certain retailers.
It is good to see Rimmers have restocked as not long ago they were 'not currently available'. £45 a set is still somewhat steep in my opinion though and hopefully once I get enough core sets to make re lining viable, we'll be able to do better than that...
What did you do with your old ones Raf?
I've kept them to hand over, hopefully at TDCIR. That's if I can get an MOT sorted out this week as I got a failure on a couple of minor points at the most inopportune time possible. Just ineffective handbrake on one side, split steering rack gaiter, a split ball joint boot and a full beam unit, but I've no time this week to source and replace.
Be aware, Sprint shoes currently in limited supply, Ford folk like Burton sell them for Cortina and Capri, but at £75 a set.[/quote]
I have a set of sprint rear shoes which were at one time riveted, I have removed the rivets in the hope that I could have them relined but I can not find anyone to do it. My 42 Jeep also has riveted brake shoes and I exchange them but my supplier is not willing to tell me where he sends them.
I have just found this which may be useful
http://villiersservices.co.uk/index.php ... cts_id=146
Malcolm
Malcolm
Thanks Malcolm, they are three miles away from me, I shall go and see them.
The folk I've been talking to so far aren't interested in one offs at all, in fact their first offering was a batch of 50 sets as a minimum order, but they do clean and refinish the metal work and box them up as part of the service so they look 'as new' when returned, but their unit price was intimated as being significantly more than Villiers!
- trackerjack
Argh!!!!! don't start em off on why the fronts do most of the worksoe8m wrote:You can fit larger rear brakes but then you have to reduce the brake pressure to the rear to have the same brake power you already had with the std drums. You have to upgrade the front.
