tap for coolant sensor
bluetriumphsteve
#1 Post by bluetriumphsteve »
Anyone know what tap size I need for the coolant temp sensor
Was changing my old one and the new one decided to cross thread in the manifold (1850HL 1977)
Unless anyones got an inlet manifold?
Re: tap for coolant sensor
#2 Post by xvivalve »
I have spare 1850 SU manifolds...
marko
#3 Post by marko »
If it's the same as the 1500 temperature sender then it's 5/8"unf.
#4 Post by xvivalve »
It is into an ally casting, so it is most likely to be UNC rather than UNF
Galileo
#5 Post by Galileo »
On my Sprint it's 5/8 18 UNF.
Edit: But you're right, coarse thread for soft metals so not sure why this is not the case, unless the fine thread aids watertightness?
#6 Post by MIG Wielder »
I've got my old temperature sensor from my 1850 and the thread O.D. measures 0.6140 in. The thread pitch measures as 0.0504 in. From my trusty Zeus book I reckon it is ( as has been said) 5/8 -18UNF ( 0.625 O.D. and 0.0555 in pitch ).
Same across the range then.
bluetriumphsteve
#7 Post by bluetriumphsteve »
Just brought a manifold off ebay for strongberg carbs in a bit of a panic because it was cheep, now is this a facepalm moment? Are the manifolds the same or different for SU. Going off Rimmer Bros website there the same
#8 Post by MIG Wielder »
The S.U. 1850 inlet manifold is RKC129. The Stromberg one is 313302. The difference is in the carb; fixings. Very few new parts available right now so it would have to be second hand.
bluetriumphsteve
#9 Post by bluetriumphsteve »
Got a tap on order, cheers guys for the help
bluetriumphsteve
#10 Post by bluetriumphsteve »
Retaped the manifold, got both UNC and UNF taps just incase and it always good to have more tool in the box. It was a UNC tap after all, worked a treat, thanks guys
Galileo
#11 Post by Galileo »
UNC? Interesting as to why your car is different, maybe a previous owner redid the thread?
bluetriumphsteve
#12 Post by bluetriumphsteve »
Sorry correction mean't it was UNF after all
