Not firing on all four
Posted: Thu Oct 06, 2016 3:42 pm
by andy from roxeth
My girlfriends 1500fwd lost power the other day and after swapping everything I could think of for good used parts and going over it with a test lamp I finally got it to start. The problem now is that it needs full throtle to keep running and feels like it only fires on two or three. I can now hear a loud knock from somewhere that I couldn't hear while spinning it over on the starter motor. Any ideas?
Re: Not firing on all four
Posted: Fri Oct 07, 2016 8:29 am
by cliftyhanger
Firing order of ignition leads? 1 3 4 2 anticlockwise. Amazing how easy it is to get it wrong!
Posted: Fri Oct 07, 2016 8:38 am
by Triumph1300
Head gasket?
Posted: Fri Oct 07, 2016 8:54 am
by trackerjack
1500's and there bretheren have their coils mounted on the suspension turret and sadly this results in the spark jumping all over the place sometimes when its damp! Typical BL :( which was repeated on the Montego :roll: .
I doubt that this is your problem though and would look to a partial blocked SU needle valve.
Oh really it could be several things and using a process of elimination hunt it down.
Good luck.
