Page 1 of 2
Fitting gutter trim
Posted: Tue Nov 01, 2016 8:07 pm
by PaulB
Struggling to fit the gutter trim, does anyone have any suggestions?
Thanks.
Re: Fitting gutter trim
Posted: Tue Nov 01, 2016 9:19 pm
Get a nice thick glove and whack it on with the heel of your hand.
Posted: Tue Nov 01, 2016 10:26 pm
by Toledo Man
This is an absolute pig of a job. That's why I left mine on and carefully masked it when I did the respray.
Posted: Tue Nov 01, 2016 10:37 pm
by soe8m
Carledo wrote:Get a nice thick glove and whack it on with the heel of your hand.
Yes easy but to add start with the bend above the a pillar.
Posted: Wed Nov 02, 2016 9:28 pm
by James467
What year is the car? You may need the unobtainable clips!
Posted: Wed Nov 02, 2016 10:24 pm
James467 wrote:What year is the car? You may need the unobtainable clips!
I've only ever seen the clips on factory vinyl roof cars (ie Sprints) Even then, they don't seem to be essential, I think they hold the vinyl in place till the brightwork is fitted!
I have a full car set of clips but they are NOT for sale, at least at the moment! Incidentally, where fitted, there are 2 different ones, the very front one on each side is different from all the others!
Posted: Wed Nov 02, 2016 10:39 pm
by James467
Don't worry Steve I have a full set including both types!
Paul, I thought they were fitted to the later cars which is why I asked.
Posted: Thu Nov 03, 2016 9:51 am
by SprintMWU773V
I also removed all my clips from my car. I'm not convinced they are necessary but kept them just in case.
Guessing well aimed and gentle use of a light rubber mallet may also help in fitting them.
Posted: Thu Nov 03, 2016 1:31 pm
by Maidstonerob
Is the gutter trim still available?
Posted: Fri Nov 04, 2016 6:22 pm
by PaulB
No its NLA
Posted: Wed Nov 09, 2016 9:36 pm
I do have at least one pair of mint gutter trims spare that I could be persuaded to part with, but they would obviously have to be collected as they are much too fragile to commit to the postal system! And couriers charge upwards of £50 to ship anything over 2m long!
Posted: Sun Nov 13, 2016 10:49 pm
by matt of the vivas
I fitted mine back after the respray with tiger seal and g clamps to hold it while it dried..
Posted: Sun Nov 13, 2016 11:28 pm
matt of the vivas wrote:I fitted mine back after the respray with tiger seal and g clamps to hold it while it dried..
That's a bit permanent for my taste! They'll certainly never come off again, I glued the GRP wings and front panel onto the Carledo with Tiger Seal, they have been on for 4 years now and survived 2 minor collisions, one from an Audi with a badly applied handbrake that rolled into it whilst parked on a hill last year and the other last Friday from the Jaywalking dog. All the seams are still tight as a drum!
Posted: Sun Nov 13, 2016 11:36 pm
Tigerseal is simply amazing.
Posted: Fri Nov 18, 2016 12:18 am
by Ictoan
I have a problem with the rear of my nearside gutter trim coming detached, resulting in it flapping in the breeze. I have been contemplating using a small pop rivet at the rear end.
Anyone else had this problem and how did you fix it, without Tiger Seal?
Tim
