Page 1 of 2
Dolomite 1500 knock
Posted: Tue May 09, 2017 3:43 pm
by RJF_70
Developed what sounds like a bottom end knock on my 1500 auto, Not there constantly but when asking for a bit more acceleration it becomes apparent!Engine ticks over beautifully as always and at low round town speeds is perfect too! Have probably decided in my head that it's a bottom end noise so my question is are the bearing caps available and how big a job is it to change the caps? Also is there anything else that it could be bottom end wise?
Thanks Rich..
Re: Dolomite 1500 knock
Posted: Tue May 09, 2017 7:00 pm
by Triumph1300
Don't jump to conclusions, bring it round to me, or Tony for a second opinion.
Posted: Tue May 09, 2017 8:24 pm
by Jon Tilson
Can be reshelled by dropping the sump. OHV's are typically strong of crank and weak of shell so caught early as it sounds
like you have then you should get away with new shells. Also check the oil pump rotors while its all off.
Bit of maneuvering to get the sump off, but its doable. The front main bearing is the only one you cant do with the engine in place IIRC, but the mains will usually be ok.
Posted: Tue May 09, 2017 8:42 pm
by RJF_70
Triumph1300 wrote:Don't jump to conclusions, bring it round to me, or Tony for a second opinion.
Ok Bruce will do if you let me know when your'e up to it! Phil and I had a good listen today and we were both under the same impression but like you say I want to be sure before I touch it really.
Haven't dropped the oil yet this year as only covered 1000 miles last year as had POL on the road then too so my plan was to do this some time this week too.
Thanks for the info Jon.
Cheers Rich..
Posted: Tue May 09, 2017 9:08 pm
It always pays to change the oil annually on a 1500, regardless of mileage. I have just taken in a 1500 Auto for breaking, that too has a light growl (I wouldn't really call it a knock) when well warmed up, under load and over 3000rpm, ie when you kick it down to climb a steepish hill. Otherwise its sweet as a nut and idles quietly and happily at 650rpm with no oil light on or any other obvious problem. I've heard this sort of noise from this type of engine before. Sometimes, all that is needed is an oil change and the timing knocking back a degree or two!
Posted: Wed May 10, 2017 6:56 am
by RJF_70
Carledo wrote:It always pays to change the oil annually on a 1500, regardless of mileage. I have just taken in a 1500 Auto for breaking, that too has a light growl (I wouldn't really call it a knock) when well warmed up, under load and over 3000rpm, ie when you kick it down to climb a steepish hill. Otherwise its sweet as a nut and idles quietly and happily at 650rpm with no oil light on or any other obvious problem. I've heard this sort of noise from this type of engine before. Sometimes, all that is needed is an oil change and the timing knocking back a degree or two!
Ok Steve, I'm going to change oil and filter anyway, nipping round to Bruce's tomorrow. It's a new noise have owned car for 3 years now and change oil every year but as said only covered 1000 miles last year so had it on my to do list but hadn't done it yet. It doesn't just happen on kick down and it's more than a new rattle, can't say accurately the revs when it happens as mines a flat dash so no rev counter. Oil light goes out almost immediately when starting and never comes on whilst driving or anything like that, idles well and really drives well but doesn't just happen on kick down it's always there when you ask for a bit more ie over 40 ish, but is also there in neutral revving manually from engine bay but at the end of the rev if you know what I mean? Glad to hear it may be other things although electronic ignition on mine, But the "Growl" is probably a more accurate description of the noise.
Cheers Rich..
Posted: Wed May 10, 2017 7:57 am
by tony g
Im about at mine over the weekend too Rich if you need a hand
Posted: Wed May 10, 2017 3:40 pm
by RJF_70
tony g wrote:Im about at mine over the weekend too Rich if you need a hand
Cheers Mate :D
Posted: Sat May 13, 2017 11:09 am
by RJF_70
So popped the caps out on rod 1 this morning and the top shell is pretty worn showing signs of copper! Plan to hopefully get a set on Monday the numbers stamped on them are VP5105 are these standard caps?
Cheers Rich
Posted: Sat May 13, 2017 11:35 am
by marko
James Paddock sells King bearings which are the old style 3 metal bearings from original.
Posted: Sat May 13, 2017 11:46 am
by Triumph1300
VP 5105 are std shells from the factory
If there are no other markings', it's std, is unground size
Posted: Mon May 15, 2017 12:45 pm
by Toledo Man
Sounds like you caught it just in time. A decent brand of engine oil should help with longevity. I'll second the Paddock's recommendation. They're one of the good guys.
Posted: Mon May 15, 2017 3:20 pm
by tony g
I wasnt aware that King bearings were tri metal. Is that definite?
Posted: Mon May 15, 2017 9:46 pm
by Jod Clark
I still have sets of STD big ends and mains here in Birmingham, AE Glacier brand. Some standard and oversize thrust washers too....
Posted: Mon May 15, 2017 10:57 pm
by Toledo Man
Rich, Jod is your man when it comes to the 1500 engines and he's fairly local too.
