Difference in version 2 heads
Posted: Fri Jul 21, 2017 6:55 pm
by mikekav
whats the difference between version 2 heads and earlier ones ?
Re: Difference in version 2 heads
Posted: Fri Jul 21, 2017 7:34 pm
by Galileo
The Later version has a larger volume water jacket, a bit of extra reinforcing around the exhaust port and a number 2 cast in the front of the head and above the right-hand inlet port next to a large AM roundel. If I remember right there's something about spring seat height difference as well, but can't quite recall the exact details.
Posted: Fri Jul 21, 2017 9:09 pm
by Jon Tilson
We talking 1850 slant 4 heads here?
If so the early ones have a slot under the inlet ports for 3 and 4 pots. Also a change in IIRC the inlet valve size? Later ones are slightly larger.
Posted: Fri Jul 21, 2017 9:39 pm
by Galileo
I'd assumed Sprint as they asked about a Sprint cam previously, but we all know about assumptions being the mother of all...
Posted: Fri Jul 21, 2017 11:06 pm
by soe8m
Jonners is so awake.
