Engine mounts.
Posted: Wed Aug 16, 2017 6:00 pm
by grumpy2
Bit of a bu99er but when doing the steering rack today found one of my engine mounts was totally knackered. If I'm right the metal plate should have the notch facing up and to the front? If so then the mount is wrong too. I guess I'll do both. What's the nearside one like to get off?
Re: Engine mounts.
Posted: Wed Aug 16, 2017 7:21 pm
by xvivalve
No harder or easier than the offside, a pair of nuts and bolts onto the subframe and a pair of nuts onto the engine bracket. The bracket with the notch is a separate part to the mounting incidentally
Re: Engine mounts.
Posted: Wed Aug 16, 2017 9:53 pm
by grumpy2
Yes I meant the bracket. They're handed I believe, notch up and forward?
Re: Engine mounts.
Posted: Thu Aug 17, 2017 6:50 pm
by grumpy2
Rack changed, both mounts renewed, steady bar adjusted and tracking set.
Day and a half of work but excellent result, the 'to-do' list gets shorter and shorter
