Page 1 of 2
MGF WHEELS
Posted: Tue Oct 03, 2017 9:54 pm
by RJF_70
Planning on putting a set I already have of MGF 6 spoke wheels on my 1500, the studs are 3/8 so can anyone recommend what wheel nuts I will need?
Cheers Rich..
Re: MGF WHEELS
Posted: Tue Oct 03, 2017 10:04 pm
by new to this
Look on ebay Revolution wheels,they sell wheel nuts 7/16 and 3/8 but not sure if there fit the MGF wheel
Re: MGF WHEELS
Posted: Tue Oct 03, 2017 10:09 pm
by tony g
Carledo / steve has them fitted too ask him Rich :)
Re: MGF WHEELS
Posted: Tue Oct 03, 2017 10:30 pm
by Triumph1300
Think you need the 60 degree taper nuts, similar to classic Mini alloy wheel nuts.
You could offer one of KAC'S nuts up to check for the taper, but I'm running m12 studs
Re: MGF WHEELS
Posted: Wed Oct 04, 2017 7:05 am
by tony g
pretty sure they are flat bottomed holes like sprint alloys, but with a larger hole for the sleeve nut, so fatter sleeve nuts needed I believe. Where Carledo when you need him lol :)
Re: MGF WHEELS
Posted: Wed Oct 04, 2017 7:38 am
by cliftyhanger
To fit with 3/8 studs is a bodge. I did it, but in retrospect it wasn't a good idea, and soon swapped to m12 nuts.
The seats are taper 60degree.
Initially I used some tapered wheel washers,then 60degree bulge nuts. The nuts on there own barely touched the wheel stud hole edges, hence used taper washers..
For the cost/effort, fit a set of freelander studs. Then use MGF/Ford etc nuts. Job done properly then.
Re: MGF WHEELS
Posted: Wed Oct 04, 2017 8:12 am
by tony g
Ah ok I stand corrected on the taper thing. Yes using M12 studs would be better really, just whether the studs come out in situ on the rear (sprints dont)
Re: MGF WHEELS
Posted: Wed Oct 04, 2017 9:45 am
by bazyerma
Hi,
I fitted them with MGF wheel studs and nuts. I bought a full set of new off ebay. Except having to take off the rear axle hubs, they work a treat.
Regards
barry
Re: MGF WHEELS
Posted: Wed Oct 04, 2017 9:00 pm
tony g wrote: Wed Oct 04, 2017 7:05 am pretty sure they are flat bottomed holes like sprint alloys, but with a larger hole for the sleeve nut, so fatter sleeve nuts needed I believe. Where Carledo when you need him lol :)
Jeez, one night away and it all goes nuts! I actually can't help much here as I converted to late Sprint hubs and rear axle with 7/16 studs. Nuts for those are freely available and relatively cheap (£24 for 16) listed for MkI Escort on Ebay. MGF wheels are indeed 60degree taper fit and have an unusually large hole so you need a nut with a wide flange or washer for 3/8 studs. Not unobtainable, but a little scarcer. Or convert to 12mm as suggested, stronger is better!
Re: MGF WHEELS
Posted: Wed Oct 04, 2017 9:21 pm
by Triumph1300
If you don't want to change studs, go to a mini specialist, who do these in 3/8.
Make sure you have enough engagement if the nut on the stud.
Re: MGF WHEELS
Posted: Thu Oct 05, 2017 7:08 am
by tony g
Lol ok Steve but bring a note in next time :lol:
Carledo wrote: Wed Oct 04, 2017 9:00 pm
Re: MGF WHEELS
Posted: Thu Oct 05, 2017 8:32 am
by cliftyhanger
Triumph1300 wrote: Wed Oct 04, 2017 9:21 pm If you don't want to change studs, go to a mini specialist, who do these in 3/8.
That is what I did, but found there was about 1mm actually contacting around the edge of the nuts. And to use a car like that is errr.....nuts.
http://www.grayston.biz/wheelnutmenu.htm and look at wheel washers
I used the "escort conversion washer" with the 3/8 bulge nuts.
But by the time you have done that, it is almost as cheap to buy new m12 studs and proper nuts.
On spitfires it is possible to fit the bigger studs without taking the hub off. But you do need to drill the brake backplate, and fit a grommet after. I can't see why that wouldn't work on a dolly.
Re: MGF WHEELS
Posted: Thu Oct 05, 2017 8:51 am
by bazyerma
Why not just use MGF studs and nuts for MGF wheel, its less than £100 for a full set, and made for the wheel?
The fit the holes in the hub with no mods.
Re: MGF WHEELS
Posted: Fri Oct 06, 2017 3:48 pm
by RJF_70
Ok thanks for the suggestions, I am going to go down the route of MGF studs and nuts I think, as I know a good MGF breaker nearby who I have used for wifes MGF in the past. But first I suppose I should get the wheels out from where they are stored and trial fit one side with some 3/8 wheel nuts I have just to see if I like them on my car!!
Cheers Rich..
Re: MGF WHEELS
Posted: Mon Oct 16, 2017 4:48 pm
by naskeet
I have similar plans for my 1974 Triumph Toledo 1300 "HL"; ideally using 185/65 R15 tyres, but my main concern is clearance inside the rear wheel arches, with 6 x 15 inch wheels having a 28 mm wheel-offset!?!
