Sprint timing
Glynnd
Sprint timing
#1 Post by Glynnd »
When the crank pulley is at TDC, which cyclinder contact should the rotor arm be pointing at?
That depends
#2 Post by Jon Tilson »
on whether its TDC no1 firing or exhaust...
Only way to tell is the valves. No 1 firing is valves on the rock...ie neither open. (or none of the 4 to be precise).
You only get 2 choices...better to look down t he oil filler cap to be sure.
#3 Post by xvivalve »
Number 1...the front one
#4 Post by Mad Mart »
If you look at the dizzy, you will see a small lug near the front. The rotor arm should be pointing towards this if the leads are in the cap correctly.
