Water pump clearance?
Posted: Mon Dec 04, 2017 8:00 am
by tony g
What is the bolt to cover clearance on a Sprint please?. Book says 010" to 025" (0.25 to 0.5mm) but I believe some run a bigger clearance than this. Be nice to make this an easy search. I tried searching and theres a few threads with Jonners' how to rebuild etc but no figure on the clearance. :)
Re: Water pump clearance?
Posted: Mon Dec 04, 2017 8:17 am
by Mad Mart
I've always done them +0.010" Tony.
Posted: Mon Dec 04, 2017 9:14 am
by Magenta Auto Sprint
I didn't bother with the feeler gauge method of shimming the water pump,
I used a length of lead wire, sat it on top of the LH bolt, tightened down the housing, removed and used a micrometer to measure the thickness of the lead wire.
I should also state that I did clean the head of the LH bolt first to ensure it was flat.
Malcolm
Posted: Mon Dec 04, 2017 10:47 am
by tony g
010" thou is the book minimum So I may go a tad bigger than that. Ive measured both sides with a depth gauge and can calc from that. Think I'll aim for 020".
Posted: Mon Dec 04, 2017 7:04 pm
by mahony
I always got away with using the thickest gasket that came with the repair kit 8)
Posted: Mon Dec 04, 2017 10:26 pm
by Flyfisherman
Have a read of this:viewtopic.php?f=4&t=7214#p67964
Paul
Posted: Mon Dec 04, 2017 10:28 pm
by soe8m
mahony wrote: Mon Dec 04, 2017 7:04 pm I always got away with using the thickest gasket that came with the repair kit 8)
Me too.
Posted: Mon Dec 04, 2017 11:13 pm
by tony g
Thats what I went with in the end. :)
soe8m wrote: Mon Dec 04, 2017 10:28 pm
Me too.
Posted: Mon Dec 04, 2017 11:21 pm
by tony g
Cheers Paul, but that thread doesnt give a dimension, at least no that Ive seen speed reading it. I know all the mechanics of how to rebuild but was after the "increased" clearance. Ive now built it with 20 thou clearance so I'll see how it goes (I have major mods going on that may well cause more problems lol.
Flyfisherman wrote: Mon Dec 04, 2017 10:26 pm Tony
Paul
Posted: Tue Dec 05, 2017 9:05 am
by Flyfisherman
tony g wrote: Mon Dec 04, 2017 11:21 pm Cheers Paul, but that thread doesnt give a dimension, at least no that Ive seen speed reading it. I know all the mechanics of how to rebuild but was after the "increased" clearance. Ive now built it with 20 thou clearance so I'll see how it goes (I have major mods going on that may well cause more problems lol.
Paul
yes no sizes mentioned - but it states the old school way of checking bolt to cover clearence "Feeler gauges" like the manual states.
Paul
Posted: Tue Dec 05, 2017 4:44 pm
by MIG Wielder
Magenta Auto Sprint wrote: Mon Dec 04, 2017 9:14 am I used a length of lead wire, sat it on top of the LH bolt, tightened down the housing, removed and used a micrometer to measure the thickness of the lead wire.
Malcolm
Now I really like that idea. I imagine you used a length of thick solder wire.
Since I reckon the actual important dimension is the water-pump vane to cover clearance, I wonder if the idea could be extended to creating a flat spiral of lead wire to overlay the pump vanes, tighten down the cover and measure the actual clearance between the cover and the vanes ?
And see how this compares with the bolt-to-cover dimension perhaps ?
