Parts inventory - what are these?
Posted: Sun Mar 18, 2018 2:36 pm
by GTiJohn
I've taken advantage of my family being out for the day and got the parts for my Sprint inside for a sort through
I've now got them sorted into Body, Chassis, Electrical and Powertrain boxes but I've ended up with a small number of parts I can't easily identify. They aren't necessarily Dolly bits but the cam with car.
Is anybody able to identify any of them please?
Re: Parts inventory - what are these?
Posted: Sun Mar 18, 2018 3:12 pm
by tony g
Pipe is the fuel pipe to the carbs- one feed from pump other 2 for carbs. The plate with 2 holes in it and i suspect a rubber pad is the heater hose outlet cover (screws to the bulkhead on the engine side.
Posted: Sun Mar 18, 2018 3:43 pm
by GTiJohn
tony g wrote: ↑Sun Mar 18, 2018 3:12 pm
Thanks Tony - I should say that the 3 items in the centre are pressed metal parts.
Posted: Sun Mar 18, 2018 4:56 pm
by GTS290N
Here's photo's of the other black metal bit, before and after.....
Posted: Sun Mar 18, 2018 5:46 pm
by tinweevil
The wiring loom is off a manual non-overdrive gearbox.
The shiny metal plate retains the right hand stalk to the steering column before fitting the left hand stalk.
Posted: Sun Mar 18, 2018 5:55 pm
by xvivalve
The unpainted bit is the clamp for the indicator stalk and the wiring is the gearbox supply (with the autobox inhibitor by-pass loop on the multi plug)
Posted: Sun Mar 18, 2018 7:26 pm
by GTiJohn
GTS290N wrote: ↑Sun Mar 18, 2018 4:56 pm
Ah ha, I've got the other metal part of that too - I'd mistaken it as a radiator support bracket!
The retaining strap has long since gone so what's best to use in its place?
Anyone need a non-overdrive harness?
Posted: Sun Mar 18, 2018 9:30 pm
by GTS290N
This stuff here is what I used after advice from this forum, it's perfect. I cut it to the correct width with a scalpel and metal straight edge:
https://www.ebay.co.uk/itm/Rubber-Pirel ... 8WmxjfnCug
I don't
need that loom, but don't throw it. If no-one else needs it and you don't want to store it, I'll pay postage and keep it for posterity.
edit: Just remembered, the bracket you thought was for the radiator used to have a piece of foam glued on to stop rattling from the washer bottle. I binned what was left of that and used some high density modern stuff, non absorbent. The colour doesn't matter since it can't be seen with the bottle on.
edit edit: If the loom is going spare, Steve is more likely to find a useful home for it than me.
Posted: Sun Mar 18, 2018 9:37 pm
GTS290N wrote: ↑Sun Mar 18, 2018 9:30 pm
I don't
I don't NEED it either, but I will take it if offered, I have a hunch that someone I know wants one, just have to remember who! It's also relatively easy to convert this non O/D loom to an overdrive one if you have the right connectors (as I do)
Posted: Mon Mar 19, 2018 8:02 pm
by GTiJohn
Carledo wrote: ↑Sun Mar 18, 2018 9:37 pm
I don't
Nothing serviceable will get binned.
Shall I bring it to the NEC this weekend?
Posted: Mon Mar 19, 2018 8:04 pm
by GTiJohn
A metre - I only need a foot!
Posted: Mon Mar 19, 2018 9:56 pm
GTiJohn wrote: ↑Mon Mar 19, 2018 8:04 pm
So buy a metre, cut it into 3 correct size pieces and sell the other 2 on ebay as ready made straps at the metre price each!
Posted: Mon Mar 19, 2018 9:57 pm
GTiJohn wrote: ↑Mon Mar 19, 2018 8:02 pm
I don't
That would be great, i'll be there on Sunday!
