Transmission noise
Posted: Thu Jun 28, 2018 10:54 am
My 1850 based kit car has just started to make a noise when I drive off and change gear. Its more of a rattle noise.
I have tried moving the car back and forth out of gear to check diff and prop shaft but it seems to be ok. The prop shaft UJ's seem solid and there doesn't seem to be a noise from the diff. When I put it in gear and rock the car forward in all gears including reverse the noise is apparent more towards the gearbox end rather than the rear. Rocking the car backwards it is not as bad.
Any idea what it could be or any other tests I could do?
Also if I have to take the gearbox out is it difficult to modify and fit overdrive. I am not worried about the length of the prop shaft as it has been cut down anyway. The car is a 1972 but not sure if it is three rail or single gearbox.
Gary
Gary
