Hi,
Can anyone recommend the best place to get hold of a rear hub puller
James
Rear hub puller
Re: Rear hub puller
I bought one from Canley Classics.
Having said that I still could not get one of the hubs off with it so please let us know how you get on.
Also see my recent thread on oil seals.
Re: Rear hub puller
When I used a hub puller I found that it pulled one of the wheel studs a bit more through the hub and as a result the hub puller was not flat against the hub and so was not getting a square pull. Once I retightened the nuts I managed to get the hub off.
Re: Rear hub puller
For what car?
Re: Rear hub puller
Hi its a 1850hl, hopefully sorted now. Have ordered a puller and will try it when back off holidays.
Re: Rear hub puller
Leave the hub nut on, it will support the thread on the end of the half shaft.
