Hi I've got the repairable upper ball joints,what are they like to fit and is there any setting up to do ?
Thanks Dave
Sprint upper ball joint
Re: Sprint upper ball joint
has any one used the repairable ball joints,how do you shim them ?
- Triumph1300
Assuming you've got the repair kit, it's a case if building it back up, and fitting shims under the circlips until you get a nicely stiff pin.
Then grease, refit the gaiter, and away
BWJ
1966 Triumph 1300 Royal Blue
1966 Triumph 2000 Blue
1967 BSA B40wd green
2018 Jaguar E pace 2018
thanksTriumph1300 wrote: ↑Mon Sep 24, 2018 9:14 pm Assuming you've got the repair kit, it's a case if building it back up, and fitting shims under the circlips until you get a nicely stiff pin.
