It is currently Sat Dec 15, 2018 2:01 am
PostPosted: Thu Oct 11, 2018 12:36 pm
Hello, my Sprint has been laid up for a number of years and now the ignition switch has decided it no longer wants to function. After unsuccessfully trying to clean it I think its time to get a good functioning one.
If it make it easier to remove its OK to cut the plug off the end where it plugs to the main wiring loom.
If it makes it easier I could also have it sent to a UK address for onward shipping.
Regards,
http://www.triumphowners.com/649
PostPosted: Thu Oct 11, 2018 1:47 pm
Hi Mark,
Do you just want the small loom from and including the round white plug that fits in the back of the ignition barrel to the multi plug that connects to the main loom at the bottom of the column? If so, I have several and can send you one complete.
(rather than cutting the plug off, if you find a narrow tube the correct diameter, or a pair of tweezers, you can use it to compress the bayonet and withdraw the pins from the plug)
Alun
PostPosted: Fri Oct 12, 2018 1:13 pm
PM sent.
