1300 fwd 1966 gearbox knocking
epcot_pete
#1 Post by epcot_pete »
Could someone please advise me on a gearbox problem with my 1966 1300 front wheel drive.
The car drives well, starts first time and has no other mechanical problems.
It relates to a mechanical knocking/rattling noise in the gearbox, but only occurs at certain rev range and at no other time.
The knocking approximately starts at 15 mph in 1st gear, then stops when changing to 2nd gear until reaching about 25 mph, then stops when changing to 3rd until about 40 mph, then stops when changing to 4th until about 55 mph when it starts again. When cruising on the flat or going downhill at 55 mph the knocking goes away, but appears again when accelerating or going up a hill. It tends to go away at 70 mph, not that I usually travel at that speed!
So the mechanical knock/rattle occurs through all gears at a certain rev range – has anyone got ideas please?
Thank You.
Pete
Re: 1300 fwd 1966 gearbox knocking
#2 Post by tony g »
Ive never looked at one of those boxes but it sounds like input shaft speed related to me. Are there drop gears after the input shaft? Could be a bearing on its way out maybe. Bruce may know a lot more I expect.
dollyman
TDC Cheshire Area Organiser
#3 Post by dollyman »
Possibly drive shaft related and transmitting the noise so it sounds as though coming from the box??
#4 Post by Carledo »
I agree with Tony, its rev related so anything after the gearbox output shaft to the diff can be eliminated. It's there in 4th gear, so that lets out the laygear cluster. Your problem logically lies in the transfer gearset between the clutch quillshaft and the gearbox input shaft.
The only good thing about this, is that that geartrain is accessible through the tunnel in the car, without removing the engine or gearbox!
Triumph1300
#5 Post by Triumph1300 »
Input shaft bearing, clutch tube loose, or clutch cover plate issue would be my first thoughts.
Have you taken the clutch cover plate off, and had a look?
BWJ
1966 Triumph 1300 Royal Blue
1966 Triumph 2000 Blue
1967 BSA B40wd green
2018 Jaguar E pace 2018
epcot_pete
#6 Post by epcot_pete »
Thanks Lads for reply's.
In hindsight, I stripped gearbox about 4 years ago and replaced syncro rings, some bearings and new, stronger design input shaft and gear that goes through clutch and top gear of gearbox. Do you think this may be the problem?
Many thanks again.
Pete
Triumph1300
#7 Post by Triumph1300 »
Does it make the noise when revved stationary?
If so, stethoscope time, find exactly where it's coming from
BWJ
