Club clutch hose
Posted: Fri Apr 26, 2019 7:45 am
by tonybsa
I have just purchased one of the clubs Clutch hoses,and I need a bit of guidance.
I noticed that only one end of the hose has a 90 degree bend-unlike the original hose which has one on each end.
Do I fit the 90 degree bend to the Master cylinder,or the slave cylinder?
What would people recommend?
Okay,.......
Posted: Fri Apr 26, 2019 9:27 am
by sprint95m
Which model of car to you have, Tony?
Re: Club clutch hose
Posted: Fri Apr 26, 2019 5:37 pm
by xvivalve
It looks as if you have been sent the 'prototype' hose! Once I'd approved the length was sufficient for all models, I asked for all subsequent ones made to have a right angle at both ends to avoid exactly this confusion. You will need to fit the right angled end of the one you have to the master cylinder, else it may not clear the bulkhead.
Posted: Fri Apr 26, 2019 8:45 pm
by tonybsa
Thanks,I have a Sprint.The prototype hose will be returned,in exchange for a production one!
Posted: Fri Apr 26, 2019 11:16 pm
by xvivalve
There's nothing wrong with the prototype, which is why I put it in inverted commas earlier, and was happy enough to put it into stock. On a Sprint, you'll actually find it easier to bleed the slave with the straight end, as indeed had the original equipment, but as the exercise was to have a single product for all models the rest had an elbow to both ends.
